Is this Spectrum dead?
Hello. First post and all that...
I have an old Spectrum +3 which has sat on a shelf for many years. Yesterday, when I plugged it in for the first time in a decade the disk drive made a loud continuous whirring sound but there was no red LED on the Spectrum itself.
Is it dead beyond repair? It's my own fault, really, I should have looked after it better.
Any advice on things to check most welcome, otherwise it can head to the tip.
Post edited by ssme on
Or if you have another PSU, test the Speccy again.
Time to get hold of a multimeter, I guess. What readings should I be getting from each pin?
You should find at least a pin with 5 and a pin with 12volts.
Oh here's something I found with Google:
---u---
/ +5 -12 \
| 0 | at the PSU cable
\ +5 +12 /
\ +12 /
Sorry I cannot get the spacing correct on my Iphone...
I know one of my +3 PSUs the 5v blew! Pretty sure that was its symptoms.
But a multimeter will show this easilly!
The +3 itself most likely has nothing wrong with it.
Thanks for the information. What component do you suspect has gone wrong? I wish I had another supply to test it with!
Assuming the 12v are ok (the 5v are generated from the 12v line I belive), there's three components you should check, two transistors (h1061 and 2222A) and the IC ca723c. You'll need a multimeter.
Here is a diagram of the power supply circuit:
http://hardware.speccy.org/hardware/Fuente+3/esquemas.html
