odd broadband behaviour
fogfog
edited November 2012 in Chit chat
you'd expect it to either work or not..
mine has been chucking a "hissy" from 4-10pm and it's a pain as when you like buying off ebay , them are normally the peak / best times.
have 2 different routers..1 seems to work all the time, where the other just seems to cut out at them specific time (an older one)
you'd again assume the router would either work or not, dunno if anyone else as ever have this situation.. rather odd one.. had the engineer out etc.. and it's giving errors etc.
oh well another engineer tomorrow turns up. the pain being that you can only have virgin or a BT line, all the others have to use BT lines.
I just find it bizarre, dunno if anyone else has had such problems
Post edited by fog on
  • edited November 2012
    I hope the bug report to your ISP is significantly better than that. "It's giving errors, etc." :(
    Good luck.
    PS. If you have two routers, and one "works all the time" and the other doesn't, then I would be inclined to suspect that the dodgy router is...err... dodgy. Really, I don't know how I do it... special powers of some sort, I guess.
    My guess is that they hate you and everyone in the office is laughing at you.
    Hope that helps?
    My test signature
    I lost my internet connection last night whilst playing World of Tanks, i restarted the router which didn't help, i was offline for about 15/20 mins the suddenly the connection came back, the same thing happened last week.
    I hope it was just the ISP doing maintanance work.
    My connection depends on where in the house I am.. but the majority of the time, the wi-fi card in my laptop can pick up 12 different routers - two Sky (one mine), three BT, one Talk-Talk (the woman who moved into the home belonging to a nice old man), Virgin and Planet Wireless among others.
    Edit: I even had connection problems when posting this one!
    That's because wifi is useless and if there are 12 networks running in range of each other then it's likely at least 3 others will be interfering with your signal.
    fogartylee wrote: »
    Nah, they're too busy hacking into Roger Jowett's PC and setting fire to his house.
    I've had issues with 2 out of 3 routers so not surprised.
    It's really a case of you get what you pay for I think. Bought one router for $30, worked fine for a little while but I had to reset it every time I needed to access the webserver/settings as it 'lost' the admin password and the default one didn't work.
    2nd one worked OK but had a lousy range
    3rd one I paid premium for and it's been working great ever since. The first 2 btw were cheap but still brand name, my new one is an Asus and was about $70.
    fogartylee wrote: »
    Hope that helps?
    not at all, thankfully you don't run the company if that's your level of "professionalism" ;) . I know this due to emailing all the directors and your name isn't on that list.. thanks for your comments, I guess it says far more about your level of helpfulness than anything.
    ccowley wrote: »
    hint : their diagnostic stuff at the exchange showed it, and it was confirmed when the engineer tested the connection from here. whats to tell them, light goes on / off.. flashes orange instead of green.hehe
    seems it's a specific router that doesn't like whatever they did to the line. If it was the router then it'd chuck a hissy all the time. it's the signal to noise ratio I'm taking a guess at. well my bug report as such wasn't needed due to them seeing on their side the sync was dropping., when that does it re-profiles the connection to a different setting / rate.
    most ISP's have to use BT's existing wiring, so it's a case of them calling out BT to deal with it (yep an engineer was here) and their equipment showed the errors were building before it got to the router.
    it's a wired connection ,
    zero you might find http://www.metageek.net/products/inssider/ is of help to you , to change your channel that you use etc.
    beanz, nah it's a decent enough netgear routers (2 of em + the one they gave me), oldish now but still. the mk1 / mk2 doesn't work at peak times (I've just been testing other older one).. although the new router the ISP gave me is better in some respects, and wifi wise not as good a signal.
