Why, Speccy?
OK, wanna see something strange?
Go to your Spectrum (or Spectrum emulator), and type
PRINT 10-100*0.1
:-o:-o:-o
Why???
PRINT 10-100*0.1
:-o:-o:-o
Why???
Post edited by memrah on
IF (3/10)<>0.3 THEN PRINT "OUCH!"
It happens that in base 10, 0.3 is a finite exact number, but in base 2, it's mantisa representation is a periodic number.
001100110011001100...............
As 3/10 is an operation subject to rounding on its least significant bit, a comparison like the above one will surely fail, not only in the Spectrum but in any computer and programming language using floating point scheme for decimal numbers (I wonder if COBOL, which is not based on floating point, will success in this test).
And this is why you should avoid comparing two floating expressions using just the "equal to" or "different to" operators. Best use >= or <= .
HAHAHAHAHA Stupid 64. :-P:-P
PS. QL passes this test. Sam Coupe fails.
(3/10)==0.3
returns False in C#. (maybe it's because of type declaration defaulted to int?)
So we should avoid floating point comparisons? But this will ruin all the fun :)
I still don't understand mantissa representation problem, isn't both 0.3 and result of 3/10 represented with mantissa/exponent style? Why they are different?
or the infamous subtraction bug in microsoft calculator.
Doing the same conversions that are done by the Spectrum should clarify the reason for the discrepancy. Hence 0.3 <> 3/10.
Dividing by reciprocals can help: 10-100/(1/0.1) gives zero.
The number 3 is a tricky customer; eg.: So they're all equal to three but all different from each other!
The error here is programmer error: you should never compare floating point numbers directly, but instead to within a known epsilon.
The Floating-Point Guide
Actually there's a well known report on a bug found in a rocket firmware all programmed in ADA. It caused the rocket to explode 36s after launch blowing away everything it had within it, like expensive satellites.
No, they usually make different even worse floating point mistakes...
This classic text ought to be read by every engineer in the world (IMHO): Personal Observations on Reliability of Shuttle, by Richard P. Feynman.
Instead of a - b * 0.1 use a - b / (1/0.1) .
Instead of 0.n <> n/10 use 0.n <> n * (1/10) .
Where a*10=b and n=n they both return zero. The () are essential, even in the second example where they could be expected not to make any difference.
The error is introduced by the two elements in each expression having slightly different values in the last mantissa byte. The alternative versions wangle it so that the last byte works out the same.
Excellent text!
It perfectly illustrates that people rarely run tests using a truly scientific approach, to really find out if an hypothesis is correct. Instead, they run tests to find enough "evidence" to claim whatever they prefer to be true, quite often adapting their criteria until it "fits". Another somewhat similar case related to NASA involved the "GFAJ-1" bacteria: there's nothing really special about identifying a arsenic-resistant bacteria, but it's worldwide news to discover a new life-form based on arsenic instead of phosphorus. Therefore a few researches (unconsciously or otherwise) tried really hard to find enough evidence to claim they found it. See further details here and here.
A related problem is that nobody likes to give bad news to their boss/investors/whatever, especially in large corporations, since this may affect their bonus/promotion/funding/whatever. Therefore people usually minimizes problems when reporting to their boss, that minimizes them even more when reporting it further, and so on.
In 20 years of experience in IT consulting, I saw quite a few times companies working on project schedules, not to determine the time required to complete the project, but merely to produce a "convincing" document to support a certain previously established deadline. When it happens, just proving it's an unrealistic deadline is frequently not considered a good enough reason to change the schedule. :)
