Dust cover?
Do you leave your spectrum set up all the time? And if so, do you have any sort of cover to protect it?
I've got a +3 and normally keep it packed up in the poly inserts that it came with. It's a bit of a faff you unpack it then set it up each time I want to use it - it'd be cool to be able to leave it out all the time, but then it'd gradually get covered in dust.
I spent a while trying to find a cover for it, but didn't have any luck. What do you use to protect your Spectrum when it's not in use?
Post edited by gutted on
Dust :)
Technically it's not specifically there to protect the +3 exactly...
Marked it out with a ruler, pen
Cut and sewed up the corners.
Did one for my toastrack and Amiga 1200..below
@beanz - that's the sort of thing I had in mind. Nice.
@guesser - that's quite an eclectic dust cover! :D
