Currys IF+ECHO KEYBOARD+ORIGINAL TAPE
Hi! I'm looking for this,
http://www.worldofspectrum.org/infoseekid.cgi?id=0008524 Organ Master tape
http://www.worldofspectrum.org/infoseekid.cgi?id=1000136 Echo Keyboard + INTERFACE
I need the whole package or another way to play the AY chip onboard with an external pianokeyboard.
I saw the sif interface + midi module , but it's too experimental.
Thanks!
Edit: If you have the interface, please take some pictures of the circuit, and send them to me. I've heard that it's a really simple interface with few components.(the only trouble will be cloning the piano keyboard....)
Thanks!
Post edited by DaRkHoRaCe on
as for the tape, you can generate one if need be.. to a cd or tape.. you have tape deck / cd player ? no biggy
I can use the tzx on wos. But what about the keyboard? I have a spare pc midi keyboard with the joyport plug (!). Is possible to convert it for the echo interface?
the pins for the echo thing is different a 14 pin connector or somethng that like .. the commodore sound expander has something similar for c64.
it's a pity bob pape isn't here still as I'm sure he could have remembered how it was dealt with .i.e. if it was totally none standard or followed the midi standard.
do you just want to mess about with it generally or with a sequencer ?
as there are few chip emulation things in VST FORMAT.
