Difference between brands of 4164 chips?
edited February 2013 in Hardware
I have gotten my hands on a batch of several brands of 4164 chips.
Examples are NEC D4164C-3 and Mitsubishi M5K4164ANP-15.
Anyone knows if any type is preferred above the other?
Post edited by bverstee on
  • edited February 2013
    It just comes down to the speed of the devices, so as long as they are fast enough.
    Guessing by the product id's you may have 300ns and 150ns devices? (On the train so can't check ! )
    In the datasheet of the Samsung KM4164B it says that after powerup it needs a 100us pause followed by 8 RAS cycles before proper device operation is achieved.
    Not sure if this is related to the above but I see erratic behaviour when I use these as a 4116 (lower RAM) substitute.
    They seem fine when I use them as upper 32K.
    So I suspect that (ignoring the speed or timing) there are differences between the many brands and/or versions of 4164.
    I just checked the Mostek 4116 datasheet and it also needs 8 refresh cycles.
    Knik wrote: »
    Doesn't sound unusual... The chip will probably need a little 'housekeeping' time after its power supply has stabilized. And a DRAM chip likely has some sort of state machine in it, which (much like a CPU) needs some cycles to initialize properly.
    1st condition is met by the machine's reset signal. Since /RAS cycles result from Z80 memory requests (any memory!) and refresh cycles (and from the ULA as well in the case of lower 16K), 2nd condition is met after the Z80 runs through a few ROM instructions. Read: 'long' before it does a RAM test.
    Interesting...
    I can't get many NEC D4164's so need to get other brands as well.
    However I think that 4116's should be replaced by 4116's ;)
    I have them in stock too.
    The usual argument goes: The problem with 4116's is that when they go pop, they often take the power circuit with them. Which can take out the 4116's after you've repaired them :-|
    Edit: well I guess if you've replaced TR4 with a robust alternative you may be safe.
    Replacing them when they die with something more stable that also doesn't require multiple power supplies is perhaps a good idea. Well it's a choice :-)
    csmith wrote: »
    Not really... It's a pretty safe guess that many working 64K*1 chips can still be found when virtually all 16K*1 chips have died. For one, because of the 4116's multiple power supply issues. Add a few years of age difference, and the fact that many more of those 64K*1 chips were produced.
    So if there's a choice, it's between "let your Speccy die" or "find alternative for the RAM". Not that RAM or ROM will ever be a big problem imho - ULA's might be though.
    An identical problem was put up once by Sinclair: let your Speccy die or modify the voltage convertor to meet issue 4 standards. The official solution then was to wait until a Spectrum went in for repair. :-)
    I received some NEC D4164C-3 from Ben.
    I tested them and they work fine as upper (32K) RAM replacements in my Spectrums.
    I'll test them as 4116 lower (16K) RAM replacements on my memory adapter pcbs this week and let you know the result.
    Tested the NEC D4164C-3 as 4116 lower (16K) RAM replacements on my memory adapter pcbs and they work just fine.
