+2b RGB to Composite
Hello , My samsung LCD TV duznt seem to like my +2b RGB scart lead , I get a picture but theres lots of snow in front of it , My spectrum+ 48k with the composite mod works just fine on it , If i get the scart lead for the +2 with the sound lead on it, will it work , Will i get a composite picture and sound if i plug the audio lead in the 3.5 hole that says sound on my +2b Or any one know of another way ? , thanx 4 ur time
Post edited by ricky006 on
What I suggest you do is try and get a decent photo of your tv's output, so that one of the more senior forum members can take a look at it and maybe help you out.
And no do not get the other lead it will either be a small waste of money (about a tenner a lead) or a big waste of money (add the cost of a new TV to that.)
As Blownapart rightly said there is a 12V pin on that +2b monitor socket so it's not one to mess around with if you don't know what you're doing.
It won't do that :p
It won't display a picture either of course :)
An old style Cathode ray tube might have a couple, in which case typically only one of them will support RGB.
I can normally tell if that's the problem, because the lead I'm using gives me a 'shadow picture' if the scart socket doesn't support RGB. You can just about make out the 128k menu, but it's in various shades of black! My old TV used to do this - until it blew up! I used to get perfect RGB picture on that but as I say the new samsung TV just doesn't like it.
The pictures full colour (so it must support RGB in some way), and it stays steady (so I think it has to by syncing correctly-ish), but there's this layer of noise overlaid on top of it that makes the whole picture unusable.
1 Scart ,1 VGA, 2 HDMI, 1 Component :smile:
Edit : Mine is a samsung 26 inch TV, model number le26d450g. So for the minute don't buy one of these if you want to plug a +2b into it!
