Looking for PC2086 OS disks
I've seen in another forum a member that purchased an Amstrad PC2086 with empty HDD and no software disks. He has installed MS-DOS, but it's having problems trying to make Windows 2.1 work.
Does anybody have images from the original disks that came with these computers? I'm curious and I was thinking about trying it with PCem.
Also, does anybody have images from the disks that came with other Amstrad PC 2xxx or 3xxx?
Post edited by Zup on
I was there, too
An' you know what they said?
Well, some of it was true!
6 disks that are labelled, PC2086 1988 Amstrad PLC
1 msdos disk and 5 windows disks.
Not sure if they still work though.
Whats the best software to try imaging them with ?
Just remember to protect your floppy disks so you can't damage them.
Thanks to John Elliot, I've got now the MS-DOS boot images from a variety of Amstrad PCs.
The problem is that I wanted to check out if I was able to make Windows 2 work in a 2086, but I've got no Windows disks. It is (fairly) easy to obtain a copy of Windows, but I wanted to know if Amstrad included any special file (=driver or custom software) for their computers.
Can anyone confirm if their Windows disks were "standard" ones or had any special software?
I can't find anything to image them, so I've zipped the contents of each. Can email them to you if you want.
Cheers
Moriarty.
I'm checking everything using PCem, the next step would be using MESS.
