Chuckie egg remake available on Android
I'm not bull****ting!
This can ACTUALLY be downloaded from Google Playstore for free!
:grin::grin::grin::grin:
Post edited by Stealthwyvern on
Accelerometer = left/right
Touch Top/Left Corner of screen = Up
Touch Bottom/Left Corner of screen = Down
Touch Right side of screen = Jump
It's a tad weird (especially on a larger screen where there's a few inches between the top & bottom corners). There are other control options in the menus but I ain't messed with 'em yet...
EDIT: The options just set which accelerometer axis is used for the left/right controls.
Top half of left side is climb up, bottom half of left side is climb down, right side is jump.
I've not tested on anything larger than a Nexus 7, so it maybe that the controls don't cover as much of the screen as they should do on 10" devices.
The other control options are to adjust for odd devices that have the tilt axes all wrong.
The controls always seem to be a bit of stumbling block for games on android devices -- there's no easy way to map 4 directions + jump/fire to them I suppose. A few more options for that might be a nice addition (accelerometer for up+down as well as left+right maybe? And maybe the option to map physical buttons to the controls for devices that have them).
Ta for releasing this. Very nice version!
http://www.worldofspectrum.org/forums/showthread.php?t=43317
