+2a double vision - uncommon problem
Helloo - I was helped by Guesser on a previous occasion on a toastrack, so many thanks to him for that!
Today's problem is the RGB display from a +2a - mono output comes with excessive ghosting/double vision:-o which is not conducive for programming!
I can't see a way to upload photos here! I originally went on the RWAP forum where I've got some advice and ideas but was told the problem is uncommon and to try here too. This link will take you, kind reader, to the pics I uploaded there and comments I got there:
http://rwapadventures.com/forums/viewtopic.php?f=5&t=77&p=209#p209
I'd be grateful for any advice on how to deal with this !
all the best!
Jeff
all the best!
Jeff
Post edited by sliderules on
For the record, the toastrack and the grey +2 are slightly different in their outputs, so a SCART cable made for the toastrack isn't necessarily going to work on a +2. The internal resistors are different and also the +2 incorporates the BRIGHT signal on the RGB, where the toastrack does not.
However, it does look like ghosting from too high signal levels, like the mate upstairs said.
interesting idea! I don't know is the answer! But I can add this to my growing list of things to look at! cheers
toastrack goes into same TV as the +2 - but with a toastrack dedicated scart cable - no problems at all, very crisp mono
the +2 I've used several different allegedly +2 dedicated cables, each of which gives the double vision on same tv as I use with toastrack. Both +2 and toastrack are also fine with CRT
the 48k does everything asked of it perfectly - I think I was maybe just celebrating it, but no I don't plug it into the flatscreen. But am thinking about a conversion.
Thank you again! any ideas v welcome!
Is it the grey +2 that uses a power plug similar to a 48K?
Or is it a black +2A or +2B that uses a DIN plug for the power connector?
I ask, because the +2 Grey uses a different SCART lead to that used on a black +2A or +2B.
Can you please confirm that the picture from the UHF TV out is okay and shows no artifacts like on the pictures you uploaded to RWAP's forum.
Looking at the pictures that were posted on the other forum, there are artifacts on the colour picture, they are just not so noticeable.
On the black and white picture, if you look carefully you can see a thin weak line ahead of (to the left) of a thicker, darker line. This is most unusual. I would say that it is a digital timing error, not any type of analogue error. It cannot be signal reflections or incorrect termination in the TV.
You cannot upload pictures/images or attachments to this forum, as this is not permitted. To show pictures on this forum, you have to upload them to a photo sharing web site, your own web site or another web site which allows photos and images to be shared. Then to show the image, use the tool button above the edit box (looks like yellow and black postcard, but I think it is suppose to be a mountain range) to link to a URL of the image that you uploaded on the other web site.
Is this problem only occurring when using a SCART cable on your +2/+2A/+2B to a LCD flat-screen TV?
Does it work okay when using a SCART cable on your +2/+2A/+2B to a CRT TV?
Yes! it says its a black +2a with din power brick etc. and yes
your ideas about crt:
it is fine rf to crt - but I've just now tried it a SCART to a CRT and I get the weird result as here (I just typed the alphabet and I get white Klingon letters on the black screen):
http://rwapadventures.com/forums/viewtopic.php?f=5&t=77&p=212#p212
I didn't believe it when I saw it - great idea, but weirder than before!
Jeff
J
Not the cheaper one please :D
I'd like something with resistant connectors and good video quality.
If someone could make one from scratch I can buy it.
Edit: at reasonable price of course :D
I suspect the TV's are switching between RGB mode and composite video mode.
Do either of your TV's have menu or settings to be manually set to RGB mode?
If yes, try this :D
so the final picture is here which is exactly the same +2a going to CRT via RF and the output is exactly what one would like!
http://rwapadventures.com/forums/viewtopic.php?f=5&t=77&p=213#p213
Mystery! Your thoughts would be very gratifying!
In sum: we have a black +2a with din power supply
RF out to CRT - FINE!!
RGB to SCART - Flatscreen - white screen ghosting on black letters and on games any mono image is ghosted, but colour stuff good
RGB to SCART - CRT - black screen with white Klingon alphabet
How weird is that?
Jeff
:-o Thanks Mark. Interesting. Initially I thought it was the lead, I have a couple from different companies but same results. The Flatscreen has no probs with RGBcomp from my toastrack, so I don't see why my tellies would be confused by the Amstrad and not the Sinclair, but I'm listening to what you're saying. I'll have a look through their settings, but normally they just detect and flash up AV/Scart before kicking into the computer's signal. But I'll go and have a play just now!
J
I got the one I'm using now off RetroComputerShack on ebay.
See also here and here (and if you search, many other threads :D )...
So, while a cable for the toastrack *might* work on the grey +2 and definitely the reverse, it most definitely will not work on a black +2A/B or +3. The Sync signal will be too low -- which is probably why the old CRT can't understand colour and proper sync, while the newer LCD TV with its digital input is only ghosting, again probably due to the interaction of a low sync signal and a digital comb filter.
