LD B,1 would make it the last pass*, LD B,0 is the max loop B can do as it overspins on the DJNZ to 255!
* or if it's a subroutine couldn't you just conditionally exit?
eg;
CALL ROUTINE
ROUTINE
LD B,n
LP do stuff
check thing
RET Z (or whatever)
DJNZ LP
RET
Additional info:
When returning you can reuse the state of the flags to see if you exitted from the condition or end of loop by. Even by the Zero-flag since DJNZ will NOT set the zero flag!!
Additional info:
And you can check the b register when you've returned to see how much of the djnz loop was executed*. This is another good reason why making a different test for exiting is better than setting b to 1.
*That is, as long as you weren't fiddling with the b register as part of your return test. And even if you were, you'd have needed some way to recover b or you'd have broken the djnz loop when not making the early return.
The check isn't needed. The condition of your flag can be reused without ANY check at all.
Something like this
CALL ROUTINE
JR Z, OUTINLOOP ; test was done on ZERO-flag!
BIS0:
NOP ; other, B = 0 from end of loop
Something like this
CALL ROUTINE
BIS0:
Yes, of course, if ROUTINE conveniently sets a flag one way or another before returning then you can reuse it without having to do other checks.
I wasn't suggesting that you'd want to do other checks, I was just suggesting that b could have some additional uses after exiting the djnz as long as you don't exit the loop by setting b = 1 and continuing to the next djnz. If b = 0 then the loop completed all iterations, if nz then it terminated early etc etc
eg;
CALL ROUTINE
ROUTINE
LD B,n
LP do stuff
check thing
RET Z (or whatever)
DJNZ LP
RET
Additional info:
Something like this
