Power consumption improvements
Hi all,
Having just received lower and upper RAM replacement modules from Zorn, I thought I'd perform some current draw measurements to see how much current consumption they save.
I installed the modules into my already Recom-fitted 4A, so first off I compared the current consumed against another 4A with the standard regulator:
Standard: 570mA
Switch mode: 310mA
So immediately we're saving 260mA just by changing the regulator for a switch mode type. Next the RAM:
Recom + Lower RAM module: 260mA
Recom + Both RAM modules: 210mA
So those three mods have more than halved the current consumption of my Speccy :)
Hope this info is of some use!
Standard: 570mA
Switch mode: 310mA
Post edited by balford on
I assume/hope you used a fixed regulated power supply. What was the voltage? The currents look about right for 9V.
I used a 1A 9v regulated supply for the tests.
Changing the Z80 from NMOS to CMOS will save you another 50 mA or so.
Won't be keeping this configuration though as my Spectranet doesn't work. Nothing to do with the lower/upper RAM boards though, as others had this problem beforehand...
