That painter thing..
edited November 2013 in Development
I'm struggling to think of a non clunky way of detecting when a 'box' has been surrounded and can be highlighted, like in the pic:
From the splendid Gamex
The best way I can think of is that a box gets coloured when a counter is zero, and the surrounding blocks decrease a particular counter (or counters for shared boxes). While this is simple enough it'll be a bit of a paint building the map (ok so not that bad).
Is there a simpler principle I can work on, or is that pretty much the best way to do it?
Post edited by R-Tape on
  • edited November 2013
    I just remembered this game, Traxx
    http://www.worldofspectrum.org/infoseekid.cgi?id=0005395
    It may give you good hints, it seems to take into account number of moves and number of changes of direction
    R-Tape wrote: »
    I would first create a data structure for boxes with easy neighbour detection. And then for each box (starting with top-left and moving down to bottom-right) try to "get out" via neighbours that are not surrounded. If I don't make it then the box (and entire path i.e. all boxes on the way) are surrounded. A simple flood fill algorithm should do the job.
    I think I'd cheat it and store the four corners for each box and tick them off as the player hits each. It'd mean you could cheat the game somewhat and hilight some squares without fully going around but then finding the most efficient way round the screen could be part of the challenge.
    I did this corner routine last night, but then I realised, as you intimate, that it's possible to enter all four corners of a rectangle without traversing all four sides, so I didn't post it. In fact, depending on the sizes and arrangements, it could be possible to enter all four corners of a rectangle and only traverse two of its sides.
    Here's the routine, anyway. Note that it uses OR to flag the corners, so they can be entered many times but only get marked once. Each rectangle's marker byte will be set to 15 when all four corners have been entered.
    ;corner coordinate table: marker, row,col, row,col, row,col, row,col
    CORNERS:DEFB 0, 1,1,  1,10,  8,1,   8,10
            DEFB 0, 3,10, 3,20, 12,10, 12,20
            DEFB 0, 8,20, 8,28, 12,20, 12,28
            DEFB 16
    CountCorners:
            ld   ix,CORNERS-9
            ld   bc,(23670)      ;BC=(SEED)
    NextRectangle:               ;row,col coords in B,C
            ld   de,9
            add  ix,de
            push ix
            pop  hl
            ld   a,15
            cp   (hl)
            jr   z,NextRectangle ;skip if already filled
            ret  c               ;end of table
            inc  a
    NextCorner:
            srl  a               ;shift marker, starts at %00001000
            jr   c,NextRectangle
            inc  hl
            ld   d,(hl)          ;row
            inc  hl
            ld   e,(hl)          ;col
            ex   de,hl
            sbc  hl,bc           ;Carry reset by SRL
            ex   de,hl
            jr   nz,NextCorner
    GotCorner:
            or   (ix+0)          ;use OR to avoid marking the same corner twice
            ld   (ix+0),a
            cp   15
            jr   nz,NextRectangle
            ;all 4 corners entered
            ;... fill rectangle ...
            jr   NextRectangle
    Deal with edges instead of vertices. A box is made of four edges. An edge is visited if the last two vertices visited define the edge. From that picture it looks like the boxes are polygons with more than four edges.
    I see nine overlapping rectangles of various sizes. I don't know how the game plays, but if backtracking is allowed then an edge can be filled in without having to pass through two adjacent corners in sequence; eg. if having to avoid an approaching threat while part way along an edge by reversing and going around the other way and completing the edge from the other direction, and then reversing again to follow another route.
    As you say, the only certain way to determine enclosure is to count the edges completed. I was thinking of defining the ends of each distinct edge (which would be 34 in this picture, as the centre block has common vertical edges with the blocks either side) x 2 for row+col = 68 bytes (Table A). Then define which four edges enclose each box, 4 x 9 = 36 bytes (Table B). Then, as the maximum length of an edge seems to be 8 character squares, each distinct edge could have one marker byte with the bits set for each position along its length which has been entered = 34 bytes (Table C) - some bits would be pre-set where the length is less than 8.
    Then, after each move, set the bit in Table C for each edge in Table A which contains that position, then check which boxes in Table B contain those edges, then check the 4 marker bytes in Table C for each of those boxes. If all four marker bytes for a box = 255 then that box is enclosed and can be filled. A Table D could also be used to flag filled boxes, so they only get filled once.
    Tables A+C could be combined, as could tables B+D. It all seems a bit of a palaver though. The corner method was much simpler & neater, but it would produce false positives. I wonder if it would be possible to add a false positive check to the corner method?
    I've just had a much simpler idea, similar to tstih's idea and R-Tape's original idea, although it relies on the assumption that moving into a red square changes it to blue (to avoid duplicate counting). Each box has a counter set to the number of squares in its border; each border square has associated with it a list of box numbers in which it appears as a border (max. 4/square, easier to always have 4, with 0 for "no box"). Each time a border square changes from red to blue, look up the boxes which contain that square and decrement their border counts; whenever a box's border count reaches zero then that box is enclosed. That would need 9 bytes for counters and 4*n bytes for the xref list, where 'n'=the number of distinct border squares.
    Shame there aren't just 8 boxes, as then it would just need 'n' bytes for the xref list, as the individual bits could be set for the box numbers.
    Oh, hang on, that could be done by having a separate mini-table for the centre box. So the outer boxes are numbered 0-7 for their bit positions in the bytes of the xref list. The central box just has a simple list of its border squares. To simplify the main xref lookup the list could be a fixed 768 bytes then just use row*32+col to get the entry. The mini-table would just have a list of numbers in the range 0-767 indicating which of the main list squares constitute its border.
    If you pass through vertex A on the way to B but turn around and pass through vertex A again, the last two vertices are A,A. If you don't ignore duplicate passes, there is no problem with this. But the image shown shows rectangles staggered which is why I mentioned, these may actually be polygons with more than four edges. The same idea applies but each box can have more than four edges.
    Like your idea above, a box/polygon can keep a count of edges still live and when one of its edges is painted, that count is decreased with reaching zero meaning it's time to fill it.
    How much processing time do you think it'll really take? Just read two horizontal lines of attributes and two vertical for each of those nine boxes, ANDing each attribute together and then just check the final total. It's not as though there's a great deal else going on. I'd just stick with the 'clunky' method and optimise it.
    Thanks for the replies all.
    I should say it's not really about processing time and I shouldn't have used the word clunky (also not specific to the picture example, just any painter game). I was mainly wondering about alternative ways to do it, seemingly there is no magic solution and the two main ways are:
    1 - Use blocks, different block types surround the box and each one decreases one or more counters depending on which boxes they touch. Setting the counters and placing the blocks in a map would be a bit faffy if done manually, though could be automated without toooo much difficulty. I quite like this one as it avoids the need for the boxes to be 'smart objects', other than 'fill box when box counter n is zero'.
    2 - Have the boxes as 'smart objects', they know how big they are and check all the way around for set blocks. Probably less faff to automate.
    Thanks again all, I'm not sure I'll end up using this idea yet, especially as I've realised just how rusty I've become!
    What makes the counting a bit more awkward is that each spot needs to store a vector to the counter it decrements when trodden on. And since it may be the border or corner of up to 4 rectangles, it means each spot needs to carry up to 4 vectors, and for a screen sized grid, that's a going to be a few K.
    Lets say you can keep it below 255 spots along the paths (shouldn't be too hard). On a screen grid (less than 1K) are the number of each path spot, or 0 for non-pathways. Those numbers get multiplied by four and applied to a longer list (1K) which can then, for each spot, list up to four box numbers to decrement. It's fast, but the pain is preparing it all.
    I think blocks and a jump table is the way to go, probably not as hard as I first thought to set up the map and include code to set the counters during screen draw.
    block_map
    	1,1,1,1,3,2,2,2
    	1,0,0,0,3,0,0,2
    	1,0,0,0,3,0,0,2
    	1,0,0,0,3,0,0,2
    	1,0,0,0,3,0,0,2
    	1,1,1,1,3,2,2,2
    counter1=18
    counter2=16
    jumptable
    	defw	solid_block
    	defw	dec_counter_1
    	defw	dec_counter_2
    	defw	dec_count_1and2
    each box has a routine to check it's counter, and knows which blocks to fill when zero
    It only needs one counter per box. Here's how I did it. Call Initialise once to draw the boxes and set the counters and call CountSquares after each move. A box gets filled when its counter decrements to zero. Calculating the fill area for each box could be moved from InBorder to Initialise and saved in Corners as it's not going to change.
    Boxes.Corners
            org  32768
    ;TopL:row,col, TopR:row,col, BotL:row,col, BotR:row,col, counter
            defw Initialise, CountSquares
    CORNERS:DEFB 1,1, 1,8, 8,1, 8,8, 0
            defb 2,8, 2,15, 8,8, 8,15, 0
            defb 1,15, 1,22, 8,15, 8,22, 0
            defb 8,2, 8,9, 15,2, 15,9, 0
            defb 8,9, 8,14, 15,9, 15,14, 0
            defb 8,14, 8,21, 15,14, 15,21, 0
            defb 15,1, 15,8, 22,1, 22,8, 0
            defb 15,8, 15,15, 21,8, 21,15, 0
            defb 15,15, 15,22, 22,15, 22,22, 0
            DEFB $ff
    Boxes.Initialise
    Initialise: ;calculate the size of each border; call once
            ld   ix,CORNERS-9
    Loop1:  ld   de,9
            add  ix,de
            ld   a,(ix+0)
            cp   $ff
            ret  z
            ld   a,(ix+3)        ;A =right col
            sub  (ix+1)          ;  -left col
            add  a,a             ;  *2
            ld   b,a
            ld   a,(ix+4)        ;A =bottom row
            sub  (ix+0)          ;  -top row
            add  a,a             ;  *2
            add  a,b
            ld   (ix+8),a        ;A =size of border
            ld   b,(ix+0)
            ld   c,(ix+1)        ;BC=TopL:row,col
            call GetAttrLoc
            ld   a,(ix+4)        ;A =BotL:row
            sub  b
            ld   b,a             ;B =row diff
            push bc
            push hl
            ld   a,(ix+3)        ;A =TopR:col
            inc  a
            sub  c
            ld   c,a             ;C =number of cols
            ld   d,b
            xor  a
            srl  d
            rra
            srl  d
            rra
            srl  d
            rra
            ld   e,a
            add  hl,de
            ex   de,hl           ;DE=bot row pointer
            pop  hl              ;HL=top row pointer
            push hl
            ld   a,16
            ld   b,c             ;B =number of cols
    Loop2:  ld   (hl),a          ;draw a red box border
            ld   (de),a
            inc  hl
            inc  de
            djnz Loop2
            dec  hl              ;HL=R col pointer
            pop  de              ;DE=L col pointer
            ld   a,16
            ld   bc,32
            ex   af,af'
            pop  af              ;A =row diff
    Loop3:  ex   af,af'
            ld   (de),a
            add  hl,bc
            ex   de,hl
            add  hl,bc
            ex   de,hl
            ex   af,af'
            dec  a
            jr   nz,Loop3
            jp   Loop1
    Boxes.CountSquares
    CountSquares: ;check for enclosure; call after each move
            ld   ix,CORNERS-9
            ld   bc,(23680)      ;row,col coords in B,C
            call GetAttrLoc
            ld   a,(hl)
            and  %0011100
            cp   8
            ret  z               ;PAPER already blue, nothing to do
            cp   16
            ret  nz              ;PAPER not red, nothing to do
            ld   a,(hl)
            sub  8
            ld   (hl),a          ;PAPER change from red to blue
    NextBox:
            ld   de,9
            add  ix,de
            ld   a,(ix+0)        ;A =top row
            cp   $ff
            ret  z               ;end of table
            cp   b
            jr   z,GotHrow
            cp   b
            jr   z,GotHrow
            ld   a,(ix+1)        ;A =left col
            cp   c
            jr   z,GotVcol
            cp   c
            jr   z,GotVcol
            jr   NextBox
    GotHrow:;on either top or bottom row
            dec  a
            cp   c
            jr   nc,NextBox      ;too small
            cp   c
            jr   c,NextBox       ;too big
            jr   InBorder
    GotVcol:;on either left or right col
            ;don't count top & bottom corners, already counted in GotHrow
            cp   b
            jr   nc,NextBox      ;too high
            dec  a
            cp   b
            jr   c,NextBox       ;too low
    InBorder:
            dec  (ix+8)
            jp   nz,NextBox
            ;fill box
            push bc
            ld   b,(ix+0)
            inc  b
            inc  c
            call GetAttrLoc      ;HL=top left inner corner address
            ld   a,(ix+6)        ;A =BotR:row
            sub  b               ;  -TopL:row
            ld   d,a             ;D =number of rows inside box
            ld   a,(ix+7)        ;A =BotR:col
            sub  c               ;  -TopL:col
            ld   e,a             ;E =number of cols inside box
    Loop4:  ld   b,e
            push hl
    Loop5:  ld   (hl),24         ;PAPER magenta
            inc  hl
            djnz Loop5
            pop  hl
            ld   bc,32
            add  hl,bc
            dec  d
            jr   nz,Loop4
            pop  bc
            jp   NextBox
    GetAttrLoc: ;calculate attribute address for row,col B,C
            ld   h,b
            xor  a
            srl  h
            rra
            srl  h
            rra
            srl  h
            rra
            or   c
            ld   l,a
            ld   a,h
            or   $58
            ld   h,a             ;(HL)=ATTR(B,C)
            ret
    You don't need to call (the fill check) every move, only when you move onto a tile you've already filled (assuming you have to visit the start and end of a loop twice; if not you need to check when a neighbouring tile not in the direction you came from has been visited instead).
    I'm sure there is a way to do the the per pixel case using that fact too, and you can calculate which side to mark as part of the loop by counting how many clockwise and anticlockwise turns you make when you complete a loop (if you make more clockwise turns, you fill to the right of the way you are facing, otherwise fill on the left). But I'm drinking and playing Dark Souls at the mo, keep falling into the deep water fighting a hydra.
    I'll think about it some more tomorrow and may post in maths & physics on gamedev if I can't work it out. Deciding which paths (and hence which turns to add up for the clockwise/anticlockwise check) form the perimeter is my main concern.
    CountSquares does that preliminary check and exits straight away if it doesn't need to do anything. The counter for each box is set to the length of its border. When moving onto a red square the square is changed to blue and the counter for each box which contains that square in its border is decremented. When a box's counter reaches zero it is filled. Nothing else needs to be considered.
    It's slightly more complicated if the boxes have more than four corners, but then just divide the meta-box into boxes which do have four corners and fill it when all its counters run down to zero - or have a meta-box counter which holds the number of constituent boxes, decremented each time one of its box counters runs down to zero, and filled when its meta-counter runs down to zero.
    Okiedoke.
    Any thought about the general case then? If you always turn left and end up where you have already been, you have enclosed an area anticlockwise, and the interior is on your left when you finish the loop. If you turn left more than you turn right, you still traced out an anticlockwise area (I think, I'll have to get out a pencil - EDIT: I'm pretty sure that is the case). Problem is when you have more paths and some areas already filled. It would be nice if there was a method that didn't have to enumerate all the possible paths (i.e. each turn at an intersection), I'll have to think about that too.
    EDIT: Something along those lines should work for non convex regions, with an arbitrary field size, is what I am thinking.
    EDIT2: You have to be able to move in non orthogonal directions (i.e. diagonal) to have more than 4 regions adjoining any given node. 4 is the worst case all others are T-junctions or corridors. Or dead ends, they don't really work with this sort of game!
    The general case ... errmmm ..
    * The screen is divided into a number of boxes.
    * Boxes may be of varying shapes & sizes.
    * Each box has a border.
    * Boxes and borders are made up of ... errmmm ... blocks.
    * Some parts of a box's border may be shared by other boxes.
    * Movement is restricted to the borders but not otherwise.
    * Setup defines each box's dimensions & each border's empty length.
    * All border blocks are initially marked "empty" (eg. by colour).
    * Each time an empty border block is entered it is marked "full" (eg. by changing colour).
    * Each time a border block is marked "full" the empty length counter for each box which contains that block in their border is decremented.
    * Each time a box's border's empty length runs down to zero (ie. it is full) then the box enclosed by this border is also filled. (Thus filling a shared border block might trigger the filling of more than one box.)
    * When all the boxes have been filled the screen is complete.
    The End
    Does that work with non convex shapes? (e.g. tracing out an L shape). I'm not sure exactly how that is handled in these type of games, but that is the case I am interested in. We don't want a node per pixel.
    My thoughts are we need to have each pixel marked as either not traversed, traversed, or part of an interior region, so needing at least 2 bits of storage per pixel (=node). We could create nodes dynamically when we change direction if we wanted.
    EDIT: I'm thinking of the classic painter game where you build paths as you go along, there are no set paths to traverse when you begin a level. Which makes a big difference ;) EDIT2: Maybe that's not how the original painter game worked (I think not, it did have set routes for you to travel on)? That's the problem I am thinking about though... Mathematician lol.
    EDIT2: Which is, how do you detect you have enclosed all regions of a 2D space (rectangular probably, but that doesn't really matter) when tracing a path. Any closed area is considered completed. It's easy to detect when you have filled the whole area, count the number of pixels inside the closed regions.
    EDIT3: Your method will work for any shape if the paths are predefined, you can just preprocess each level. You can just check all the points between straight line nodes of the graph to verify you have visited all points along the path.
    Yes, that was my idea. If the player can just wander around all over the place until they find their own tail then it's rather more difficult.
    Yep, I realised that the original game didn't work like that.
    I'm sure there is a solution to the problem if you make the network as you travel along, it probably involves building a network dynamically and doing a graph search.
