FS: Low Profile Keyboard
Got one of these for sale, open to offers but its going to need a bit of attention as some of the keys dont work and the space bar keeps sticking, ive got the bar for that separate and three out of the four screws and nuts needed to bolt down the speccy board. Literally just dont have time to devote to this right now so its going as is. On one corner the plastic has broke off (pictured)
Post edited by Macc on
Hi Macc, Im interested.
How many of the keys dont work? Does the Spectrum motherboard fit inside the case and would the case restrict any peripherals?
Does the keyboad use a plastic membrane? If yes, is it a bestoke one, or do any of the Spectrum ones fit?
Can you PM with a ball park figure that you would sell it for?
As regards keys that do/do not work, the majority do, caps lock I know doesnt and im fairly sure 1 and maybe a couple of others dont. Pretty sure its down to some missing screws under the keyboard but like I said, got too much going on at the minute and just havnt the time to investigate further.
Pricewise, just PM me with an offer and we'll go from there
