Using a Euro Sinclair PSU in UK
edited January 2014 in Hardware
I've got a EURO1400 PSU with a Euro plug. Am I right in thinking I can just cut the pug off and change it to a UK plug, and it will work fine? The only difference I can see is UK is 240v and EU is 220v.
Post edited by Hairy on
  • edited January 2014
    Hairy wrote: »
    Hi, I believe most European countries have a nominal voltage of around 230VAC on their respevtive grids, which means you will probably have a few percent higher DC voltage from the PSU (roughly 4.5 - 5 %) so that will probably be safe.
    Hope this helps,
    Berty.
    EDIT: I just looked this up on Wikipedia: http://en.wikipedia.org/wiki/Mains_electricity#Voltage_levels
    Author of BertoMenus, soon to become BertoBASIC +3 ;)
    Feel free to help yourself to the Sinclair ZX Spectrum +3 Manual.pdf
    I always do it the other way around; I must have replaced about 25 UK plugs with so called SchuKo ones. Works just fine.
    schombi wrote: »
    I've done that myself a few times too, and as you say; no probs at all :)
    Single phase AC Supply voltages are 'harmonised' now across Europe / UK / EU, at 230v.
    In practice, most of Europe still has roughly 220v and the UK roughly 240v, just the spec changed to 230v +10% / - 6%.
    It is probably fine to just swap the plugtop in this case. But it is worth keeping in mind that mains voltages in places near to large sub-stations in the UK are often right upto the 252/253v tolerated voltage, to allow for volt-drop further down the line. This can, in some cases, cause problems or shorten the life of older/cheap electronics designed for European use.
    i have done this many times too when i bring stuff back from the UK.
    just think about it, you can buy adapters that do this too. or even mobile/tablet power cables with interchangeable pins......
    i also changed a german 3 point extension cable and added a UK plug so i can use three german appliances in the UK when i am over :-)
    p13z wrote: »
    Aye, we usually have ~250 volts here, presumably so that stuff further out from the transformer stays above 230
    Hairy wrote: »
    Yes ;).
    You could also use a UK to Euro conversion plug (adaptor) like this..
    See http://en.wikipedia.org/wiki/BS_1363#Conversion_plugs_.28BS_1363-5.29
    You can get them from some electrical shops or online (eg ebay) :smile:
    Hairy wrote: »
    This should not be a problem. Worst case - the output voltage of the PSU may be around 9% higher (than a UK PSU) if Sinclair actually used a transformer wound for 220V, this will just cause a bit more heat to be dissipated by the 7805 voltage regulator.
    It is however possible that Sinclair just used the same transformer for 220V areas as that used in the UK, in which case the only difference is the label and the plug :p.
    If you have a multimeter you could always test it. Keep in mind that they are unregulated and so the off-load (when not connected to the Spectrum) voltage will be higher (typically between 10.5V to 12V).
    1024MAK wrote: »
    Yes ;).
    That's a very neat solution! I didn't know they even existed. :-o
    Thanks for all the replies. I think I'll use one of them adapters, as I like to keep things original if I can.
    Hi there,
    Just check the voltage on and off load.
    I have a euro 1400 PSU here that was outputting 17v off load and 15v on load which caused
    the internal TR4/TR5 circuit to stop working. The unit would not boot correctly and it was
    only when I placed a 12v regulator in the PSU that the Spectrum came back to life!
    Russ
    The_Bert wrote: »
    I have at least 3 appliances (bought in the UK) that were supplied with one of those conversion plugs already fitted on. Very handy when I need to hide the mains cable through a small gap and the other end of the cable is directly wired into the appliance.
