mirroring bits
edited January 2014 in Development
If I have a string of 1408 bytes, each of which has one bit 'b' set, what's the shortest way of mirroring that string, so that each bit set at position 'b' gets moved to position '7-b'? The bit positions change from byte to byte, as they're plots on a curve.
  • edited January 2014
    Something like this, though this doesn't work as it messes up when testing the end of the string address.
    ld hl,$stringstart
    	ld de,$stringend
    lp	push hl
    	ld a,(hl)
            ld b,$08
    lp0     rra
            rl (hl)
            djnz lp0
    	inc hl
    	sbc hl,de
    	jr c,lp
    	ret
    jamorski wrote: »
    ld hl,$stringstart
        ld de,$stringend
    lp    push hl
        ld a,(hl)
            ld b,$08
    lp0     rra
            rl (hl)
            djnz lp0
        inc hl
        sbc hl,de
        jr c,lp
        ret
    POP HL?
    No idea, eating a banana and trying to code is too much for my small intellect! :smile:
    Instead of doing RRA in a loop the fastest way would be to use a mirror table which is a 8 bytes big as I understand so no problem with memory
    Put the table on equal page start (C=0)
    LD HL,DataStart
    LD BC,TableStart
    LD DE,1408
    Loop
    LD C,(HL)
    LD A,(BC)
    LD (HL),A
    INC HL
    DEC DE
    LA A,D
    OR E
    JR Z,Loop
    The loop counter could be probably optimized too.
    There are several ways to do it, depending on how much you care about performance or size.
    Here's a solution using unrolled loop:
    ld hl,$stringstart
    	ld bc,$bytes
    loop:
            ld a,(hl)
    REPT 8
            rra
            rl e
    ENDR
            ld (hl),e
            cpi
            jp pe,loop
    	ret
    And another solution using a 256-aligned lookup table for mirroring:
    ld hl,$stringstart
    	ld bc,$bytes
            ld d,$lookuptable/256
    loop:
            ld e,(hl)
            ld a,(de)
            ld (hl),a
            cpi
            jp pe,loop
    	ret
    This CPI as loop control is a nice thing. I'll add it to my tricks :)
    Building upon some of the above ideas, (namely Jamorski and Einar Saukas's)
    InPlace
    	ld hl,StringAddress
    	ld bc,StringLength
    .lp0
    	ld a,#01
    .lp1
    	rr (hl)
    	rla
    	jr nc,.lp1
    	ld (hl),a
    	cpi
    	jp pe,.lp0
    	ret
    Tabled
            ld h,high MirrorTable
            ld de,StringAddress
    	ld bc,StringLength
    .loop
            ld a,(de)
    	ld l,a
            ldi
            jp pe,.loop
    	ret
    And also my own silly variation just for the sake of it :) 8 byte table at any address and maybe a bit faster than InPlace
    WhyNotHaveBoth
    	ld de,StringAddress
    	ld bc,StringLength
    .lp0
    	ld hl,MirrorTable-1
    	ld a,(de)
    .lp1
    	inc hl
    	add a
    	jr nc,.lp1
    	ldi
    	jp pe,.lp0
    	ret
    As an aside, the jump condition is 'parity even'.
    Hikaru wrote: »
    Tabled
            ld de,StringAddress
    	ld bc,StringLength
    .loop
            ld a,(de)
    	ld l,a
            ldi
            jp pe,.lp0
    	ret
    Brilliant!
    Hikaru wrote: »
    That's probably slower than my unrolled loop version on average, but if you use a 8-aligned table instead, it will work better...
    Hikaru wrote: »
    I just edited my post above to fix it, thanks!
    Not tested. An awkward way to do. It's fast but probably not the fastest one.
    loop    ld      a, (hl)
            add     a, a
            jp      c, is80
            jp      m, is40
            cp      $08<<1
            jr      c, less08
            jp      z, write  ; $08->$10
            add     a, a
            jp      m, is20
    is10    srl     (hl)      ; $10->$08
            jp      next
    less08  cp      $02<<1
            ld      a, $40
            jp      z, write  ; $02->$40
            jr      c, is01
    is04    rrca              ; $04->$20
            jp      write
    is01    rrc     (hl)      ; $01->$80
            jp      next
    is80    rlc     (hl)      ; $80->$01
            jp      next
    is40    ld      a, $02    ; $40->$02
            defb    $f2       ; jp p, xxxx
    is20    ld      a, $04    ; $20->$04
    write   ld      (hl), a
    next    inc     hl
            djnz    loop
    This just sorta came up all of a sudden.
    InPlaceV2
    	ld hl,StringAddress
    	ld bc,StringLength
    	scf
    .loop
    	rr (hl)
    	jr nc,.loop
    	cpi
    	jp pe,.loop
    	ret
    Hikaru wrote: »
    InPlaceV2
    	ld hl,StringAddress
    	ld bc,StringLength
    	scf
    .loop
    	rr (hl)
    	jr nc,.loop
    	cpi
    	jp pe,.loop
    	ret
    Nice :)
    Hikaru wrote: »
    InPlaceV2
    	ld hl,StringAddress
    	ld bc,StringLength
    	scf
    .loop
    	rr (hl)
    	jr nc,.loop
    	cpi
    	jp pe,.loop
    	ret
    Wow. You are God.
    That is ingenious!
    I came up with a way to reduce the size of the lookup table, if I understand the DAA instruction correctly.
    Tabled
            ld de,StringAddress
    	ld bc,StringLength
    loop:
            ld a,(de)  ; 1,2,4,8,10,20,40,80
            cpl          ; -> fe,fd,fb,f7,ef,df,bf,7f
            add a,0
            daa         ; -> 64,63,61,57,55,45,25,85
            srl a         ; -> 32,31,30,2b,2a,22,12,42
            sub 12h   ; -> 20,1f,1e,19,18,10,0,30 (49 bytes)
    	ld l,a
            ldi
            jp pe,loop
    	ret
    Time: 7+4+7+4+8+7+4+16+10=67 per character.
    I couldn't find any other cheap manipulations of the data that would reduce the range further, although no doubt they exist :)
    Hikaru wrote: »
    I don't think that can be improved upon. Thanks.
    Kweepa wrote: »
    You can reduce the table from 128 bytes to 13 bytes with something like this:
            ld      h, high MirrorTable
            ld      de, StringAddress
            ld      bc, StringLength
            jr      lp0
    lp1     rrca
            rrca
            rrca
            rrca
            add     5
            ld      l, a
            ldi
            ret     po
    lp0     ld      a, (de)
            cp      $09
            jr      nc, lp1
            ld      l, a
            ldi
            jp      pe, lp0
            ret
    Wow. You are God.
    Hikaru wrote: »
    InPlaceV2
    	ld hl,StringAddress
    	ld bc,StringLength
    	scf
    .loop
    	rr (hl)
    	jr nc,.loop
    	cpi
    	jp pe,.loop
    	ret
    Just a quick look:
    Where is here the mirroring for i.e. 10101111?
    Dr BEEP wrote: »
    Just a quick look:
    There is a restriction in the input, one 1 bit and seven 0 bits, so only 8 of 256 values are legal ($01, $02, $04, $08, $10, $20, $40, $80).
    Ok, didn't know that!
    You can use an 8 or 16 byte lookup and mirror each half of the byte separately. (16 possibilities for a 4bit half-byte, you can pack 2 into each byte for an 8 byte table, 16 bytes otherwise).
    That's what AntonioVillena's code above (with the 13 byte interleaved lookup table) is doing, or trying to do.
    I wrote another version of it before realizing:
    MirrorTable:
    defb 0,80h,40h,0,20h,0,8,4,10h,2,0,0,0,1
    ld de,StringAddress
    ld bc,StringLength
    loop:
    ; 7+7+7+4+16+10 = 55
    ld a,(de)
    and 0fh
    jr z,upper
    ld l,a
    ldi
    jp pe,loop
    ; (7+7+12)+7+4+4+4+4+7+7+4+16+10 = 93
    upper:
    ld a,(de)
    rrca
    rrca
    rrca
    rrca
    and 0fh
    add a,5
    ld l,a
    ldi
    jp pe,loop
    ; avg. 74 cycles per loop + 14 byte interleaved table
    By comparison, Hikaru's solution is about 143 cycles per loop. The OP was asking for the "shortest" answer, so this is just an alternative that balances speed and size for future reference.
