Hmm, loaded up Sanxion on another 48k+ I have here only to find that when it had loaded there were no enemies on screen, furthermore on loading Atic Atac the player sprite "slid" around and couldnt exit the screen
I would suggest running a diagnostic as the player sprite in Atic Atac sliding around suggests memory chunks being moved or corrupted in some strange way.
The usual suspects apply - ULA, processor, memory. My gut feeling tells me in that order. There isn't much else that can go wrong!
I'll guess that the most likely is a RAM fault, followed by a multiplexer (that interface the RAM to the Z80) fault, then maybe a Z80 CPU fault. I don't think a ULA fault would cause this, but may be wrong.
Looks like it could be quite a localised failure in that IC as the memory between C000-FFFF checks out according to the test ROM, even though it's the same physical IC that provides 8000-BFFF.
This would explain why the symptoms are so specific (and benign for a RAM failure), and would seem to rule out a multiplexer failure also?
http://mdfs.net/Software/Z80/Exerciser/
ULA checks out ok btw
