Cybernoid POKE required.
Ummm, I'm not absolutely sure this is the right place to post this, but is there a POKE to remove the music from Cybernoid 128k? I still want to keep the sfx though while I play.
Yes, an odd request, but it will make sense... eventually.
Thank you. :S
Thank you. :S
Post edited by Graz on
Load it up into an emulator with a debugger and have a look at the I register. That'll point to the table of bytes which then point to the interrupt service routine. Somewhere in there will be a CALL to the music player, along with perhaps some other stuff sandwiched between a load of PUSH instructions at the start and a load of POPs and a RETI and/or RET at the end.
If POKEing out the CALL with zeroes stops the music you're on the right path. You may then need to find the address of the music initialisation routine, which will probably be located immediately before the play routine called by the instruction you just removed with the zeroes. Calling that instead would normally silence the music if it has already begun. Nothing worse than stopping interrupt-driven music half-way through and not knowing which routine turns off the 3 channels. :)
I should qualify this by saying I have no idea whether or not Cybernoid works in this way, but I'd be surprised if it were not something along these lines.
Egghead Website
Arcade Game Designer
My itch.io page
Snapshot here if you like
This method is not without it's problems - if you're killed and start a new game then the music starts up again...
JP: That'll suit my purpose to a tee, thank you very much.
Johnathan: That's certainly something I'll look into. Good to know this sort of thing. You're a whizz!
POKE 33280,0 ($8200,$00)
