Metal Man walkthrough
edited March 2014 in Games
If you were watching the recent Russian game compo a little bit you probably turned your attention to Metal Man Reloaded, a very colourful and impressive platform game inspired by Robocop.
If you were too lazy to complete it yourself, now I made the recording :)
http://www.rzxarchive.co.uk/m/metalmanreloaded.zip
Some screenshots:
Post edited by Ralf on
  • edited March 2014
    Great work Rafal!
    Is it a final version of the game? After some corrections of English texts?
  • edited March 2014
    Great work Rafal!
    To be honest I don't know. I've just downloaded it just from the compo website.
    If you ever try to map it Pavero, try to find all secret places. I failed at this task. They are hard to find and I could find only one of them but as the author wrote on Russian forums when you see the map it becomes clear where they should be - blank spots on the map.
  • edited March 2014
    It sure is a great game, it would have made a great follow up to the original Robocop back in the day.
  • edited March 2014
    im gonna have to map this to get anywhere
    What is that effect called where the character seems to have a shadow around him to prevent color clash/square edges, is it sprite masking?
  • edited March 2014
    Ralf wrote: »
    For mapping it will be probably necessary to remove a static background texture. After this intervention the number of blank spots can increase dramatically. :-)
    BTW, in which level did you find your secret place?
  • edited March 2014
    Level 2, close to the press used to crush the safe:
    To get into secret place you have to press down (or up???) at proper place and an invisible lift will appear and take you to normally unreachable part of location.
  • edited March 2014
    slenkar wrote: »
    I thought it was simply using whole-character occlusion; the larger enemies are. But looking more closely at the main character, when the gun is held diagonally, it's more detailed than that.
    I guess it would just be a fat mask; 8-pixels wide instead of 1. Though horizontally, not vertically, so the platform immediately below is not erased.
  • edited March 2014
    And here's a video of Rafal's walkthrough:
    http://www.youtube.com/watch?v=LvUNnq1UI7I
  • edited March 2014
    joefish wrote: »
    exactly =)
    namely:
    for economy of memory, only few masks used for main character.
    enemies don't use masks
    Brand New Games for ZX Spectrum www.olegorigin.org
  • edited March 2014
    Pavero wrote: »
    nobody helped me. it's my own translation, as is. (I didn't create the separate thread about the translation, but I wrote it in the compo thread)
    in 2-3 days I will make official release. translators (spanish, polish - all languages) are welcomed, and english translation editor too =) I'll send source english texts, you will type your name in 'Credits' section of game instruction as translator or english text editor...
    UPDATE: hikoki and Rafal help me with the English, Spanish and Polish translations!
  • edited March 2014
    Ralf wrote: »
    If you were watching the recent Russian game compo a little bit you probably turned your attention to Metal Man Reloaded ... If you were too lazy to complete it yourself, now I made the recording :)
    Thanx 4 playing!! so far the only few people could complete the game =)
  • edited March 2014
    thanks for the look at the masks
  • edited March 2014
    Oleg it looks really well made. I'm interested in technical details too... have you written anything about that?
  • edited March 2014
    Well Oleg, to be honest I cheated a little bit ;)
    If you haven't heard about rollback - it's a bit like game save. While recording you press a key and create a save point. You play further and if something goes wrong you press "back" key and go back to the saved point. This way you can repeat till you succeed.
    By the way, I'm definitely interested with helping with Polish translation. It shouldn't be much work, there isn't so much text in the game.
    I'll write you a private message in a minute.
  • edited March 2014
    If you want, I can make the Spanish translation ;)
    No need to put me in the credits, though.
  • edited March 2014
    Ivanzx wrote: »
    Thanks! =) hikoki already responded to my message and (I believe) helps me with Spanish translation
  • edited March 2014
    Ralf wrote: »
    If you haven't heard about rollback - it's a bit like game save...
    Of course, I know about Rollback. Even in this case the game is not so easy =)
    Thanks for your help with Polish translation! Soon the world will see the Polish Metal Man! Cool! =)
  • edited March 2014
    this game is simply amazing...
  • edited March 2014
    oh! it seems, I can't describe it briefly =)
    I worked hard over game of months, and could write the whole book (but, unfortunately, I won't do it =)
    However, technically there is nothing difficult. for example, I at all didn't use memory copying via PUSH/POP, using LDI sequences. The map uses blocks 8*1 chars (and additional one-bit data for floor). Sprites use a simple per-char drawing, but there are some interesting features of overlapping: some chars of sprite use direct drawing, other via OR. And also mixing of sprite color and a background color is used. Same for blocks.
  • edited March 2014
    Thanks! =)
  • edited March 2014
    Thanks! =)
    Oleg, I'll work on the translations and send them to you, Ivanzx and Ralf for your review.
  • edited March 2014
    hikoki wrote: »
    Cool, nice to see that people were interested before :)
    If you want me to review it, Im in then ;)
  • edited March 2014
    And I can help with Czech translation (from English version). Just PM me :-).
  • edited March 2014
    The Polish version is complete!
    Thanks to Rafal
    Tomorrow I'll create a site with English/Polish/Russian release
    Czech and Spanish will appear soon =)
