My TV is dying....oh no's!
So I'm thoroughly enjoying my return to Spectrum life at the moment. But something is becoming clear to me. Or to be more exact, clearly fuzzy to me.
My TV is dying. :(
It's a 14 inch Sony Trinitron and it's around 20 years old. My Spectrum's are all showing jumpy image tendency's. Re tuning the TV doesn't work (when using old UHF cable). Even the SCART signal appears less than 100% clear. It's the same on my other 8bit computers as well.
So to meet my current (and future) 8bit needs, I thought about getting a cheap-ish flat screen TV and one of these:
http://www.amazon.co.uk/SCART-HDMI-converter-convert-connect/dp/B0092IAA3I/ref=sr_1_1?ie=UTF8&qid=1395705733&sr=8-1&keywords=scart+to+hdmi
Has anyone had any experience with this device? Is this what I should be getting? Also, does anyone know what I should be looking out for TV wise? Will a modern LCD or LED take the odd resolution's of 8bit computers? Thanks in advance.
My TV is dying. :(
Post edited by Amplitude on
http://www.ebay.co.uk/itm/Gadmei-Ultra-XGA-Game-Box-Wii-XBOX-PS3-on-PC-TFT-TV-/350883931044?pt=UK_VideoGames_VideoGameAccessories_VideoGameAccessories_JN&hash=item51b24fe3a4
It can tune in to analogue input from a telly aerial and output it to a VGA monitor. Obviously your TV would need a VGA port.
http://www.ebay.com/itm/121085303937?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
As with the old Sony, joefish is absolutely correct with dry joints and electrolytic capacitors, unfortunately on these old sets, there are many caps that you will need to replace.
Pierre
My suggestion would be to get hold of a cheap LCD television with a composite video input (most have one) and modify your Spectrum to output composite video. The picture will be better anyway.
I'd save buying the converter box, and go for a TV that has all of the inputs that you will want. I bought a small TV a while ago, and it had composite video, HDMI, SCART and VGA.
It works brilliantly with an Acorn BBC B micro and a Sinclair QL (using SCART leads from retrocomputershack). However, when I tried my +2B and +3, I got a double image (like a very sharp single ghost image overlaid on the first sharp image). I think this may be a problem with how the SCART lead feeds some of the control signals to the converter box, but I have not investigated further.
- The actual 8 bit computer.
- The method of connection / SCART lead used.
- The actual TV used.
I have a Sharp Aquos that works with all my 8 bit (and 16/32 bit) computers.Oh and most "LED" TVs are just LCD TVs that use LEDs for the backlight (behind the LCD) instead of CCFL (Cold Cathode Fluorescent Tube).
Are your Spectrums standard and unmodified?
Which models?
Ahh well, that would be me with the soldering iron. It will be a good bit cheaper than a new TV. But the weight and space it takes up are beginning to make storage problematic. I'll try this first I think this coming weekend.
That might be worth a try. But no SCART input, which is a bit of a no no. All my computers (BBC Master, C64 (yes, I know....), ZX Spectrum 128k, +2, and shortly to be two working +3's) have cables for SCART connections. I'd like to keep them at that, or as close as I can to it. I've already got the kit you see. All the machines do have RF output, with varying degrees of success (mostly poor), as does my Spectrum +. So I'm as yet undecided on this at the moment. I might take a gamble.
Now this might be a soldering mission too far, and as you say a little expensive. Only if my revived soldering skills can make the +3 repairs a success would I attempt something on this scale. So the checking of the Sony TV contents will be my first choice.
You know, it does a bit. But gets better when it heats up. It could be a bad joint somewhere. But the disparate hardware types I use are an issue. I tried one old-ish LCD TV with my 8bit collection, and the results were less than perfect. Artifacts from the BBC Master and Spectrum's, huge lines on the C64 (yes, I know....).
That's good to hear about the other hardware types. I wonder if the voltages of the +3 output signals over SCART are a little different in some way. I might try throwing myself and a multimeter at my working BBC Master or C64 (yes, I still know....), and compare them to my +3 signals. Just for investigative purposes. Good way to spend a Saturday afternoon if your me. :)
So I think I'll try a poke around inside the TV first. Safely of course. Check the joints etc. Thanks for all your inputs.
When I can get near the family TV again, I will see what tinkering I can do...
That looks very nice indeed. Very impressive.
