Super League Soccer - for the Amstrad PCW
Hi, I made a game called Super League Soccer for the Amstrad PCW series. It ran on Mallard Basic under CP/M. I released it in 1992 through DG Software in Bradford who went bankrupt.
I do not have a copy of the game but one buyer has contacted me and asked me if I can convert the game to PC.
I am happy to do this but could somebody volunteer to convert the game code from it's current format into ASCII text files so that I can re-compile in Visual Basic and add a few more bells and whistles to the game.
I will ask someone to send me a copy of the disk and would be pleased to forward to anyone who can convert for me.
I do not have a PCW anymore so I can not access the old code !!
Any thoughts.
[ This Message was edited by: sharpeystu on 2005-05-17 14:53 ]
Any thoughts.
Post edited by SharpeyStu on
http://cpczone.emuunlim.com/boards/index.php?act=idx
Ooooh! ... you better run and hide and hope the womenfolk of WoS don't come after you for that remark ;)
Skarpo
Is it just me ? Asking for the code of an Amstrad game at a Speccy forum ? Bit like me asking at a C64 forum if anyone has the code for an old Speccy game i wrote ?!?!
Post your request at that Amstrad forum and they should be able to help you in some way (At least its the same computer).
Does anyone know where one exists ?
Thanks again
[ This Message was edited by: sharpeystu on 2005-05-17 16:28 ]
You'll be asking for Blur songs next at an Oasis forum or Megadrive games at a SNES site ;)
Seriously though that Amstrad site is the one to try as its the main site for the Amstrad series of computers.
WOS wont obviously list emulators for any other machines apart from a Spectrum. You wont see links for a C64 or Amstrad one there !
I just typed in "+emulator +amstrad" in a search engine and a lot popped up.
http://www.worldofspectrum.org/sdp/
You might get help transfering the software if contacting the people listed at the above page or perhaps you could ask Nick at CPCzone.
Start an Ebay-watch, maybe you will find your game there?
To psj3809:
If you found several PCw-emulators, why not post it here? I checked emuunlim and found http://www.seasip.demon.co.uk/Unix/Joyce/index.html
Please be more helpful, this isn't news ;)
[ This Message was edited by: ivarf on 2005-05-17 22:16 ]
dunno if it will help, if not it's an interesting site anyway...
Please be more helpful ? When it comes to Amstrad emulators i'm not too fussed about helping people. I mentioned already about how to find them on the internet.
I typed in +amstrad +emulator +download and one of the first links i found was...
http://www.emuunlim.com/downloads.php?System=Amstrad+CPC
Theres 6 emulators here for the PC and some others below. Theyre not hard to find !
PCW and CPC are totally different computers. PCW isn't much more relevant to CPCZone than to WOS. The common factor is that they all were made by Amstrad and that they have the same or similar disk-hardware.
BTW, there doesn't exist 6 different emulators for the PCW. You searched for CPC-emulators.
[ This Message was edited by: ivarf on 2005-05-18 09:59 ]
I dont really know anything about the Amstrad range of computers so i dont know the difference between a PCW or CPC hardly. I think though the people at that Amstrad site will have a be more useful than anyone at a Speccy site as i'm sure many CPC owners might have had a PCW etc. Either way its a bit more sensible to search there than a Speccy only site.
Yep cant find many PCW emulators just 'Joyce' which seems to be on quite a few sites
They have another common factor, and with the Spectrum +3 also: they can run similar flavours of the Amstrad version of CP/M Plus. Thus some programs can be executed in all of them.
[ This Message was edited by: NotFound on 2005-05-18 11:26 ]
Well there is likely to be someone that can help at CPCZone, as they do a lot of preservation work.
If the program was not saved with the ',p' option then it would be fairly easy to extract; just LLIST it and capture the printer output, or save it with the ',a' option and extract the saved file from whatever emulator you're using. If it was, then you need to crack the protection; PCW Plus published a program to do this and I should have a copy of it lying around somewhere.
I think moving the files over to PC format and then re-compiling is the way I want to go.
Forgive my ignorance on such matters but could you also help... I no longer have a PCW, I will ask for a friend to transfer by Re-saving each of the *.bas files as ,a (ascii) on a PCW 3.5 disc, how do I then get the PCW disc into standard PC compatible format as my PC 3.5" drive will not be able to read the disc... will it ?
www.freebasic.net
You'll be able to recompile the sources under Windows and Linux without changing almost anything (appart from the lo-level stuff).
http://www.seasip.demon.co.uk/Cpm/oldflop.html
