Help me fix my grail ZX 128k Spectrum
Hi all,
Ok today my grail toaster rack ZX spectrum 128k turned up. I finally found one and for a reasonable price. I powered it up and..... Nothing
I checked the voltage on the 5v rail and nothing.
Anyone got any pointers on where to start to maybe try and fix this, or can anyone fix it for me for a fee?
Post edited by Beaps on
Verify that you've got power coming from the PSU, and also check that the connector from the motherboard to the regulator on the heatsink is attached the right way round - someone could have been messing with this and not put it back correctly!
If all this checks out, try replacing the regulator with a 7805 or 78S05.
Sounds like either the regulator has failed or the connector was incorrectly replaced.
The 9v supply should be present on pin 1 (leftmost looking at the top of the regulator), and you should see 5v on pin 3.
In a toastrack Spectrum 128k, it is mounted on the black metal heatsink on the right hand side of the machine. It will have the type number "7805" written on it (the number will normally be in the middle of other letters and sometimes numbers).
The pins, looking left to right with the metal tab (that is bolted to the heatsink) at the top are numbered 1, 2, 3. With the left hand pin (pin 1 ) being the input, the middle pin (pin 2) being the 0V/common/ground) and the right hand pin (pin 3) being the output (for a 7805, this is +5V).
If you want, I can post some pictures, just give me a bit of time to process them...:D
With your multimeter, place the ground probe on the middle pin and check the voltage on pin 1 (left), this should be above 9v. Be careful not to short the probes!
Once 9v is confirmed, repeat the measurement except with pin 3 (rightmost). You should see almost exactly 5v on this.
If the above is what you see, then the regulator is fine.
Try this first and report back :)
Whenever poking about on boards that have power applied to them, ensure that you do not accidentally short out any connections. It is very easy to move slightly and then as a result your meter probe / logic probe / 'scope probe can move and short between adjacent pins. So be careful ;-).
Now, in order for us to help you, it would be helpful if you can report back your results :).
I presume you know that on digital electronics like the Spectrum, all voltages are taken with respect to 0V/ground?
So what voltage do you get on the lead connected to the 7805 regulator pin 1 (the input)?
What voltage do you get on the lead connected to the 7805 regulator pin 3 (the +5V output)?
Try measuring +9v from the leftmost point (blue wire), leaving the black probe in the middle position.
If you get +9v from here, then the regulator is most likely toast.
If you don't, and you've already checked and verified the power supply, then it could be the power socket at fault.
Maplins do carry replacements for both, but let's see what's broken first :)
Then test pin 1 and pin 3 of the regulator again...
You can pick up a replacement from Maplins, here's what you need.
Pick up some thermal compound while you're there and smear a bit between the heatsink and the regulator when you're fitting the new one.
You don't even have to do any soldering :) Just make sure that you replace the connector to the regulator the right way round when refitting.
A word of caution - this may either fix your problem, or bring us one step closer to getting it working by removing one of multiple faults. So don't get your hopes up.
Then apply a thin smear of thermal grease to the metal tab of the new 7805 regulator. The idea of the thermal grease is to fill in any small holes and voids with heat conductive grease, thereby displacing the air from areas where pockets of air would otherwise be present.
What is not wanted is for a large amount of grease to form a thick sandwich which prevents the metal of the regulator from touching the metal heatsink.
Do the mounting screw up nice and tight. In order for the 7805 regulator to work correctly, it has to be able to transfer the heat that it generates to the heatsink :).
Good luck :-) and welcome to the world of electronic repair :grin:.
Do let us know how you get on 8-).
Legged it to my chav pc shop and bought some grease. Followed the above instructions and....... It's works (I am doing the splits & moonwalk right now)
The only problem I have now is the down arrow on the main screen don't work, up arrow key and enter work tho?
Here's what you need, replacement is fairly straightforward.
Congratulations on the repair :)
Do you mean that the down arrow key does not work?
Try instead pressing CAPS SHIFT and "6" at the same time. It could be a fault with the keyboard membrane.
How do I bring up that tape tester program
If real tape, what type of recorder is being used?
If MP3, are you using an iPod/smartphone/tablet, or a laptop/desktop?
This thread may be helpful.
I just hooked up my laptop to test & it loaded but I want to use my iPod. I tested my iPod but I think the volume on max is still to low. How do I boost the volume on the iPod
As I use the headphone output on my PC speakers for external game loading, I'll defer to others with experience in this area :)
