Ocean's 'Road Race' inlay
Have you still got your copy of 'Road Race' given away with the May 1987 issue of 'Your Sinclair' magazine? It came with no inlay didn't it! Cheap skates! Poor thing looks ugly with no inlay just sitting there all forlorn in a tape box.........
Well, now it can sit along side the rest of your Ocean collection! (if you have one of course!)
Full size image available here: https://www.sendspace.com/file/h8pz6n
It might be sh*te, but at least it now looks good! :)
Post edited by Mark R. Jones on
Mark R. Jones
Who was this mysterious "Sheik" fellow? Or are you sworn to secrecy? (I see he also coded Donkey Kong, perhaps he wanted to keep that quiet!) :)
I didn't even know this game so I'll give it a try.
It was free for a reason.
(Ill die if he says MS Paint):-D
I can answer that. He used Adobe Photoshop CS 5.1 for Mac.
Had you thought of trying Illustrator, as thats generally what I've used all along for inlay and instructions recreation, mainly the Ultimate Play the Game ones I've been doing for some time.
It allows a lot more flexibility for editing the text and boxes etc.
the illustration is a piece of retro excellence;
However, the choice of font for the title is poor (does not illustrate speed or racing) and the treatment (semi-transparent, blurred drop shadow) does not fit stylistically.
I'm not sure if the effort to fix it is worth it; but a 80s style logotype would have been more suitable (ie like weclemans, outrun, etc..)
https://dl.dropboxusercontent.com/u/28052510/YSPoster17%20corrected.jpg
To remove the printing process halftones, whilst minimizing blur (this is the absolute best method)
Scan the image in at an ultra-large size (800% or even 1600%) at 300 dpi (this will result in a very large file, often several hundreds of megabytes)
Then, using photoshop (or similar) convert the scan to CMYK.
Then, view the individual colour channels one at a time.
On the CMK channels, one at a time, use guassian blur until the halftone just disappears (useful to view the scan at 400% for this). Be sure to use the correct radius - not too much, not too little; just enough and no more for the halftone to merge.
On the yellow (Y) channel, guassian blur the image until it is entirely smooth (you can use a very large radius here).
Convert the image to LAB colour
View the A and B channels at 400% - they should be free from halftones. If there are slight artifacts, you can introduce a very slight radius of guassian blur to fix this. But very very slight
View the L channel and apply an auto levels correction. Viewing all three channels, fade this correction as neccessary so the colours "look correct".
Resize the image using the "best for gradients" method to 100% finished size at 300dpi.
At this point, you can do any cloning and fixing to the image to remove specs and dust etc (because it is now free from the halftone, making it much easier).
Still in LAB colour apply "Smart sharpening" to the L channel only, to re-introduce sharpness to the image, but not so much as to introduce artifacts. Lens sharpening is often a good tool, as it introduces apparent sharpness without too much local contrast and artifacts.
Now convert to RGB (for screen) or CMYK (for print) using the appropriate colour library.
The sucess of this method relies entirely on the quality of the original print and the original scan.
Original prints with linescreens of at least 150 lpi and good registration will work very well.
Linescreens of 100 lpi not so well. Below this, it requires so much blurring to remove the screen that the image becomes too soft (but that may be better than the halftone?).
Poor registration will also cause problems. If it is out of register, it can be fixed somewhat by shifting the channels, one pixel at a time, once coverted to CMYK. This is not brilliant, but often you will have no choice.
The scan has to be perfectly flat. Often the orignal image will have printing on the back or be on dirty, scuffed paper. Place a piece of thick BLACK card behind the original image to be scanned. (this will stop any printing showing through but stopping the light from the scanner reflecting back off of it). Then put some heavy books on top of the image to hold it flat. Try and get it exactly square on the scanner. Rotating it to make it straight will introduce artifacts.
I'm quite happy to do this process if an original scan of sufficient size is provided
Anyone thought about doing one for the missing 'Sinclair' version of Tranz AM G29/R?
Cheers
BP
Well, thats all very concise! :)
Actually I did start to do the Sinclair missing Tranz Am inlay. I'll have a look how far I got.
Sounds interesting, would be nice to complete a gap in the collection :-)
it looks a lot more long winded that it actually is because the instructions assume that the reader has never used photoshop (which you obviously have!) - it takes just a couple of minutes.
The important thing - which takes the longest - is getting a good, flat, clean scan.
Wow! I'm impressed. Looks awesome.... :o
Wow! :o
Thats much further than I've got so far, looks really good!
Very nice! It appears you've used Myriad for the titles and text. The actual typeface used on these inlays is Syntax.
I've only got these two but I'd imagine Cookie is the same...
You're simply not trying hard enough, Mark ;)
Anyway, here's a version of it with no logo. So, come on, who can come up with the best one? Have a go and come up with something jolly. Don't put your logo on the one shown here, download the slightly bigger file (link under the pic). Remember to post a version of it here and a link for the full size file so people can choose what one they want! :)
Biggest version: https://www.sendspace.com/file/tew2cz
I?ve never been called that before on a retro computing forum..! :)
