Is my ZX81 RAM Pack OK?
Hi guys
I've just taken my 16k RAM pack apart to give it a clean inside and out and i noticed these strange burn type marks!?
You can see it mainly on the PCB where the chips etc connect to the PCB... is this burn marks!? Is my RAM pack damaged I haven't even tested this yet as I'm waiting for a RF cable...
Also is it me or are those capacitors bulging?
I just thought i'd check before connecting it to my ZX81...
Post edited by dreamscape on
You can check what's in front of you to be sure, same rules apply as on your other thread :)
IPA (iso alcohol) AKA tape head cleaner
Acetone (AKA nail polish remover)
MEK (Methylene Chloride) AKA polyweld, Nitromores paint stripper
Parrafin (AKA kerosene, jet fuel, white spirit)
Cellulose paint thinners
Naptha should work too, sold as Zippo lighter fuel.
Do I need to tell you not to smoke whilst playing with lighter fuel? Oh, and do I need to tell you not to play around with Meth Chloride? It's been linked with cancer apparently, although you can still buy it in the UK as a modeller's polystyrene cement.
This is a great example of something I was trying to point out in a previous post. Again, meant with the greatest of respect to the original poster.... Those caps are well over 30 years old, you KNOW you should change them, even if they look (and work) just fine.
Lloyd.
I need to get a better brush will do that tomorrow as at the moment its hard getting into the tight areas but i've made it look abit better already.
Before:
After:
Before:
After:
It may be helpful.
