Hmm.. A few posts made yesterday (31/08/2014) have been deleted.. I wonder why? :-)
Maybe wos just couldnt digest sylvia easily. ;)
If you dont mind to post again your post from last night, who has disappeared.
It contains interesting technical details and two very nice pictures, as an example of your custom fli conversions.
One important aspect when considering creating image conversion routines is also the pal mixing. For example, even though the c64 only has 16 colors, its possible to have much more (without interlace) by taking into account placing specific colors next to each other which blend in to produce another shade
The below is a non laced example (using my custom MUCSU-FLI method) FLI per line 8x1 and sprite underlay to increase the color density.
And when using interlace, it can also be exploited to not only allow mixing of similar luma across fields, but also utilising the pal blending. This actually gives over 300+ colors.
All above are via crt output utilising the pal blending
http://zx-pk.ru/
