Giving up on Spectrums
Hi all...
Bit of a downer post here... I'm really close to giving up on Spectrums.. My 48k has given me nothing but head aches since day one... and today is possibly the last straw.
I have a black and white picture issue at the moment which i've ordered a replacement chip for. That was annoying enough but also my keyboard membrane (brand new) started packing up on me. I've literally typed about 4 or 5 commands in total on this membrane.
It only seemed to happen when i closed the case so mailed the seller (who shall remain nameless at this stage) and he told me to put something behind the ribbon cable as its common for the cable to come away from the contacts when the case is on... seems logical so i tried it.
Did that and it didn't work so i took it back out and then tried a slightly thicker piece to make it touch more did that and tried to connect it and while pushing down against the ribbon cable 2 of the contacts on the metal side just simply fell off... These membranes are extremely poor quality obviously no excessive force was used at all.
So now I'm left with yet more crap to buy for this annoying 48k... It really is one thing after another with it and i think it's time to give up. Whats worse is i actually glued the tin cover on over the keyboard thinking the membrane would last many many many years so now i doubt i can even remove it which means i need an entire top half of my 48k...
Annoyed :x :(
Post edited by dreamscape on
  • edited September 2014
    tell me about it
    one 48k+ the keyboard ribbon has split
    grey +2 with velesofts mutant HAL won't work with any interfaces (it was doing fine till the other day)
    one +2b refuses to work with my divides yet it is my main gaming machine that sits under my plasma with a divide attached, the other has popped it's ram
    even my speccies I think are working have same stupid quiks about them
    can't find my toast racks power supply
    I'm ready to sling the whole f****** lot in the bin, working ones too
    Definetely the best model, in terms of Duration and resistance is the black +2. I have had in the last 10 years 3 different ones, and only one Problem. They also load games in General very accurately, I would say that 80-85% of the games. I have always been reluctant to use Divides...
  • guesserguesser
    quickly sets up a disposal service :-)
    /me quickly sets up a disposal service :-)
    Don't give up!
    I know where you're coming from as my first purchase was sold as 'was working but unable to test', which of course meant it didn't work.
    Unlike you I haven't a clue about hardware, so didn't even attempt to fix it, instead I sent it to the mutant caterpillar repair service (Spirantho on WOS) and he fixed it nice.
    And that's my advice, if you just want a working Spectrum send it to him :-)
    That's the thing i can accept when things go wrong on a 30 year old machine but when an apparently new product falls to bits in my hand it really drives me mad.
    I've actually got a +2A and I agree they are so hardy, work so well and i will be sticking with mine now. The 48k will go in the bin I can't be bothered with it anymore.
    I'd also like to note that the seller, dataserve_retro on eBay who also runs http://www.dataserve-retro.co.uk was extremely unhelpful the best thing he could say was "Oh dear - you must have put the plastic at the wrong side of the membrane leg. You may have now damaged the membrane." I'm not stupid I do know which side to put it onto... the traces just fell apart no excessive force, nothing. As far as his membranes go I would recommend to all of you not to ever go near them they are EXTREMELY bad quality. I managed to type around 4/5 commands on mine and now its broke.
    Avoid like the plague!! :x
    I thought RWAP was the one to buy best quality membranes from.
    IIRC there was a batch of very poor ones around (maybe still are) that should be given a bit of a wide berth.
    This must be one of them then. I can't work out any other reason why a "new" product would be such terrible quality.
    It started playing up with the case on first I'd have to lift the case to get it to work and I contacted Dataserve_Retro they told me to put plastic or something on the other side of the ribbon so i did and when putting it back in the traces fell to bits. I could accept if i had been too forceful or something but I used barely any force in fact with the plastic on the back of the ribbon it went in easier than it would normally.
    Terrible product and seller isn't interested. It's put me off bothering now. Same goes for my ZX81 which needs a new keyboard... screw it now.
    R-Tape wrote: »
    Well the direct translation of that phrase from ebay English to normal English is "tested it and it doesn't work".
    I always put a bid of "not tested" hardware representitive of a bid for non-working hardware. So far I have not been disappointed, every single one has arrived as non-working hardware (usually I'm just after spares or a repair project)
    Yep, Rich at RWAP software should be everyone's one stop shop for membranes. I have one provided by him in a machine that's been plugged in and out hundreds of times, and the tails are still as good as on day one.
    What you're learning is that the rubber key Spectrums are not the most reliable machines in the world, and the premium charged by RWAP, Macc and others for fully refurbed machines is very much worth it if all you want is a guaranteed working machine.
    Buying cheap Speccies off eBay etc and fixing them up is also fun, as long as you adopt a methodical approach and not take failures to heart too much :)
    Edit: totally agree with Winston, anything sold on eBay as 'not tested' is code for 'doesn't work', and should be bid on as such!
    I've bought 2 membranes (48k rubber and 48k+) as well as a number of other bits n bobs from http://www.dataserve-retro.co.uk and had no problems at all.
    @dreamscape. Keep going, you will get there in the end and IT WILL BE WORTH IT!
    BP
    balford wrote: »
    I've bought multiple membranes from Rich, and spoken to him on the phone before as well and he's been fantastic. Helped me with my first Spectrum fault and set me off on the right path for troubleshooting. His membranes are top notch too.
    I may need to get another one off Rich again soon, depending on the state of my latest "not tested" purchase. :p
    bagpuss22 wrote: »
    BP
    Yep as bagpuss says. I know how annoying the failures are. I've had one where after replacing the membraine, new capacitors, and comp modded, it worked fine for about 30 mins, then died of a lower ram fault. :-(
    The later Amstrad models seem more reliable, but can be fussy loading certain games. I have the +3 with a Multiface 3, external cassette recorder, and a 3.5' floppy drive for drive B. Keeps my speccy enjoyment alive:D
    Just thought I'd post a link to my most epic Spectrum failure to cheer you up/provide some amusement (delete as appropriate) :)
    I'm sorry if I sound a bit rude here, it is not intended, but having read some of your previous posts and threads, I have to ask whether it is really the components letting you down in all of these? I sense from some of your threads that you may not be being patient enough with these delicate old computers. I had similar problems early on in the repair of my collection of Spectrums, because I was being impatient and expecting immediate results. However, numerous errors and frustrations later, I have learned that there are no short cuts or quick fixes, and that patience and extreme care is really critical.
    Don't give up: it is rare that in doing a basic repair you destroy the spectrum, unless you ram the soldering iron through the ULA or something. However, patience, and some of the right tools (the other thing I learned the hard way) are what is needed. As you see in these forums, everyone is keen to help!
    Simon_Carr, In some cases yes I admit it was my fault no harm in holding my hands up and I do so about my mistakes here. I am learning quite alot and we all start somewhere. I have been very open about my mistakes here in the past. I have my strong points and weaknesses...
    ... But, when a brand new item used 4/5 times breaks apart in front of you when all you are doing is putting it into the slot it was designed to use with no excessive force then I'm sorry, but the item isn't and perhaps never was fit for purpose and I'd never accept blame for a crap product.
    On a brighter note though I have found a better (and cheaper!) seller (rwap on here) and I'm happy to report that I have ordered another membrane and will try one last time to sort this machine out. I was so impressed with his quick replies and helpful attitude (unlike DSR) that I decided to do a bit more business with this guy and buy some other bits too including a nice new ZX81 keyboard/membrane.
    Sorry for all my disheartened posts and I seriously appreciate you all keeping my chin up. You have a great community here one which one day I can hopefully add value to.
    :-D
    We have the technology to rebuilt it! :-D
    Right, that's better - lets start again.
    Right, you've glued the metal template down onto the top panel - what glue have you used?
    When you replace it, use double sided adhesive tape - then you use a hair dryer set to high to help remove it later for replacing the membrane.
    Depending on the glue you've used, you may be able to use hot air to soften the adhesive?
    In all honesty, you can buy replacement templates, but they are far too expensive for my taste. A cheaper option is to buy a duff Speccy from Ebay and transplant the board/new membrane over - that way you'll get a few spare parts to use also.
    Spare parts can be got from RWAP, Sintech and several other places.
    Whilst I agree with what you're saying, the customer services of the seller you've used previously could do with some polish, but you have to understand that keyboard membranes only tend to get fitted once, maybe twice and that's it - they're only designed for "normal" use. Ask Rich of RWAP (or any seller for that matter) what they would do if you tried to return a new membrane you've fitted five times or so. They are business men, they do not design, engineer or manufacture. They sell you a product that is fit for purpose and that's it. With all the best will in the world, no seller will absolutely guarantee a membrane that's been changed 5 times, especially since fitting and refitting has been done by somebody other than themselves - what you do with that membrane is beyond the sellers control. You've been unlucky, sad to say, unfair as it is, but that's how it is. Just don't use that seller again (I bet you don't plan to either ;) )
    Read those documents I sent you in PDF format - those will teach you which components are which, will explain polarity, will explain how to solder and why you can't just go at a 1mm copper trace with a 30 Watt iron. A 12 Watt Antex is enough and I personally use a 17W Antex iron for pretty much everything spectrum. You just can't unscrew a cassette tape with a carpenter's screwdriver, proper tools for a proper job.
    Get some soldering practice - those documents contain projects you can build, including a pretty decent continuity tester - get some practice before you start playing with a 30 year old FR4 PCB.
    Don't be scared to ASK us on here, we're here to help but listen to us rather than going it alone and causing problems that you have to fix at the expense of more time, money and frustration later on.
    Slow down dude, it will come to you in the end.
    Oh bugger!<br>
    dreamscape wrote: »
    :-D
    Don't we all! I know how difficult it is to do it properly early on: I am still in the process of sorting out an Issue 2 board that I pulled up a trace on some time back by mistake. However, patience, and practice, as DEATH says, really makes the difference. Oh, and a soldering station you can control, and DEFINITELY a good desoldering iron! ;-)
    But stick at it, these great little computers depend on folk like us to give them a future.
    I should just note, I've never had any problems with the seller you mention, and have bought quite a few components from him over the past couple of years... Seems like bad luck on your part there, but you won't go wrong with RWAP.
    dreamscape wrote: »
    Daft question, but did you ask the original seller to replace the membrane as the original was faulty?
    dreamscape wrote: »
    Surely a membrane is built to be put into the slots then closed up in the Spectrum and that's it? Why would anyone need to take it out and out back in again 4 or 5 times?
    No problem there already dealt with that :D Slowly took the top off and spent about an hour carefully removing the old glue... sticky tape next time.
    Very true! I thankfully mine came off fine so no worries there.
    Just don't use that seller again (I bet you don't plan to either )
    You're not kidding! :D
    After his first few replies I didn't want to talk to the guy at all let alone ask for help.
    It's had various repairs. sadly my 48k is a one thing after another deal so It's been opened afew times. I still think you should be able to open and close it a number of times before it falls to bits. Hell I've had originals which I've been able to open up 9+ times and its been fine so why shouldn't a new one?
    Anyway, again thank you all for keeping my chin up and at this stage I'm going to just leave the hate messages etc for dataserve lay to rest. Like DEATH says perhaps I've just been unlucky, it happens so... end of, onward and upward now.
    I've ordered a new membrane for both my ZX81 and my 48k :D
    There ya go mate ;)
    Just remember, bottom line is - it's just a circuit board. No need to let it beat you, no need to get angry with it. Just treat it like a naughty child and give it some love and patience, it'll respond properly eventually ;)
    For what it's worth, many of us have been "on the edge" of throwing it all in and off to pastures greener - you certainly aren't alone in that respect.
    Welcome back :)
    Oh bugger!<br>
    Ah nuts, I'm not Elite anymore :( Now look what ya made me do.......
    Lololol :P
    Oh bugger!<br>
    Sorry mate :lol:
    Edit: jesus CHRIST! :lol::lol::lol::lol::lol::lol::lol::lol:
    Turned the machine on today to do some tests with a multimeter on IC14 and... its completely dead... no buzz from coil, no TV output... nothing...
    I.. am.. DONE! :lol:
    Bye guys
    Is it possible something's up with the PSU?
    Composite modded Speccies generally put out some kind of video signal unless there's no 5v supply (check output of 7805 reg) or the ULA is removed or seriously toasted :D
    Go hunting for solder splashes! :cry:
    Sit down, then laugh at the irony - you have to see the funny side!
    Remember what I told you - rule #1 - Thou shall check voltages
    Is the PSU actually working? Do you get 12 volts on pin 1 of the 7805? 5 Volts on pin 3?
    You know the drill, get your multimeter out!
    You did pay the leccy bill, right? :P
    Oh bugger!<br>
  • edited October 2014
    Been there done that and given up on the Speccys but then you get the bug again and want to them. Keep them stored nice and safe until you get the bug again or you will regret in selling/throwing them out.
    Oh and dont go and throw them out I am sure there are people on here that would jump at the chance of having them.
