Raspberry pi buyer advice
So I'm considering buying a pi for Xmas, can someone point me towards a decent bundle, one with a wireless keyboard as I'm going to plug it into my TV.
Could you also recommend some add kits that are floating around.
The vast number of stuff out there makes it difficult to sort the wheat form the chaff.
Thanks
Thanks
Post edited by chop983 on
https://imgur.com/a/5qgRU
some guys gutted a snes and stuck a pi inside, loaded with emulators.
looks awesome :)
Not sure I've seen any bundles with a wireless keyboard though. The bundles usually try to do things as cheap as possible.
The B+ has composite video, it just doesn't have the phono socket any more. Instead it's on the tip of the TRRS socket.
Also, I'd recommend not to buy an unbranded power source... most of them won't give you the advertised curren (I have a 1.5A one that don't work reliably wirth the 700mA Raspberry Pi). A good 2A PSU (or better, a good PSU and a powered USB hub) would be a better choice.
About SD cards: get any branded 8 Gb card. Speed is not important: the raspberry SD slot is slooooow.
An' you know what they said?
Well, some of it was true!
Id highly suggest getting a extra spare sd card or 2, a mains powered usb hub (the one on the pi site is good as it doesn't "backfeed") and a case (or you can make one out of lego).
I use mine primarily for a media centre and have a 32 gb usb stick for storing video on.
The usb hub is definitely needed if you are using wireless keyboards/mice or a wifi dongle as they use a lot more power than ethernet/wired devices and the pi will run poorly due to the lack of power without it. I don't know if this was fixed in the new model but back when i first got my model B it was pretty much unusable without the hub as it crashed constantly and was very flaky.
Also, one thing to bear in mind about the B+ model is that the different ports make it incompatible with a lot of the cases designed for the A/B models. That said, having enough USB ports built-in not to have to use an external hub would go a long way towards offsetting that.
http://uk.kano.me/
http://www.amazon.co.uk/gp/product/B00BBJTGRM/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Actually, I saw it yesterday and it was around ?27 or so, but I thought for just under ?6 (the description still says it contains a Raspberry Pi) I had nothing to loose! They also had another version going for about the same price too. I'm guessing they're having a clear out as this is a model B and most people are after the B+ but it'l give me a taste and see if it works.
That's if it turns up ;-)
*EDIT* They've cancelled my order due to a "pricing error" which I expected them to do anyway, but I thought I'd try, just on the off chance. I'd take it up with Amazon, but I can't be bothered to be honest. If I decide to buy one eventually, it won't be from them!
