Joytsick Interface damaged Spectrum
Hello All,
Sob.. I am a plonker, I did the cardinal sin, I was testing a bunch of joystick interfaces that I got off ebay and one didn't have the keyway and now I don't have a working Spectrum 48K+ (6A)!
I get a black screen, border and inner, but I checked the ULA and it's fine.
The voltages on the lower RAM are not correct, it appears I have lost -5v and +12v. Does this mean the lower DRAM is now toast?
My coil has some modification (done prior to me owning the board) to it so I'm not sure how to test it. Basically under the board there's a resistor linking the two outer pins of the coil. A second modification goes to R61 from the bottom inner pin of the coil. Does anyone know what this is?
Using a MM and testing TR 4 I'm getting 6 and 1193 on the legs (+ in middle) and 0 and 693 (- in middle).
For TR5 I'm getting 778 and 776 on the outer legs (- middle) and 1515 and open circuit (+ middle).
So I assume TR4 is toast but TR5 is okay?
Is there anything else I should check?
I should be put in stocks for a week and everyone throw rotten fruit and veg at me! I can't believe I did this!
Post edited by Korinel on
Your 4116's may have survived - I'll pop in a new TR4, check resistances as per Zorn's video, power up and test voltages and then go from there. You may be lucky :)
Personally, I'd remove ALL the lower RAM chips, make sure there are no solder splashes, then tackle the power supply. Get the power supply giving the correct voltages, then replace RAM chips with sockets, and replace RAM chips with one of Zorn's lower RAM boards and just pray you don't need an upper RAM board too.
A word of warning - issue 6 boards are notorious for having traces that un-bond themselves from the PCB substrate as soon as you look at them. I'd personally leave it to one of the techs on here (Ian, Zorn etc).
The Coil mod is throwing me somewhat, not sure what it is doing, any ideas?
Yep, I learnt that recently :) http://www.worldofspectrum.org/forums/showpost.php?p=800492&postcount=33
