HALT: Why always 4ts?
Instruction breakdown of halt is like that:
PC 4ts.
That means it fetches instruction byte from ram which tooks 4 ts and then does nothing and reads the ram again to do nothing again until a reset or interrupt.
if halt is already read by cpu, why it tries to read the ram again? if it's not reading the ram again and again to execute the HALT, why it still takes 4 ts to handle the interrupt?
I mean if cpu executed HALT at cycle 5, and if interrupt triggered at cycle 6, cpu will not jump to interrupt until cycle 9.
What's the technical detail behind this?
PC 4ts.
Post edited by Arda on
If this is the case, then the NOP instruction needs to complete before the interrupt is handled.
Oh, right. Stupid question again, sorry. Flu got me. :)
I'd say internally if there's no interruption it executes something like "DEC PC", setting the program counter to its previous value so the same HALT instruction is read and executed again and again.
- Does the Z80 continue to fetch instructions while in the HALT state? (that is: repeated memory reads). Or does it perform refresh cycles only, without actually reading the memory.
- If so, what does the Z80 do with the opcodes read?
In most cases this wouldn't matter, but not always. For example one could construct external hardware that changes the opcode read @ some point (I mean: reading the same memory location 1000 times need not necessarily return the same value every time). Which could make the Z80 snap out of the HALT state even though no interrupt occurred. That is, if the Z80 actually reads memory in the HALT state, and executes what is read.For questions like this, my preferred source is the Mostek MK3880 Technical Manual, which has this: (page 23)
Sounds logical. So R register keeps being updated, too. And thus when HALT is exit-ed, R value may say something about how long the Z80 was in the HALT state. Then:
Hmm yeah why not. Anything special / exceptional translates to: more logic = more transistors required in the CPU's design. Rather avoid that! :razz: So... the Z80 does do memory reads while HALTed. Followed by:
So, the values read are discarded, and the Z80 executes NOPs internally.
Knowing that, it's only logical then that intruction timings, interrupt sampling points, DRAM refresh etc is the same as for regular instructions. As far as possible, that is. Except of course the PC stays @ the same value for a while. Which makes me wonder about one tiny detail: the memory location fetched repeatedly, is that the "HALT" opcode's location (PC unchanged from when the HALT opcode was first fetched), or the next one (instruction after the HALT) ?
Any questions? :smile: :grin:
Very interesting question and another question appears. One says that instruction like LDIR, LDDR, CPIR, CPDR, OTIR and OTDR doesn't update PC when it is repeating. Such instruction has 2-byte opcode (it's ED prefixed), so 2 memory reading must be done each time it is executed. In that case, I think, the memory is read and opcode isn't discarded but interpreted. Am I right?
After executing the HALT instruction the Z80 keeps doing an opcode fetch of the next instruction until there is a maskable interrupt (if enabled), a non-maskable interrupt or a reset. I don't know whether this next opcode is (a) latched inside the Z80 but ignored or (b) not latched at all. I suspect (a).
I thought of doing this but it is impossible. PC is incremented at the end of the HALT instruction then it stays at address HALT+1 until halt is exited.
The latter as already mentioned. I know all about this because of the extensive tests a friend and I did on the Z80 Special Reset. For more details please see
http://www.worldofspectrum.org/forums/showthread.php?p=811710#post811710
This article mentioned in this thread explains in detail that the CPU keeps fetching the instruction following the HALT, but discards it.
EDIT: Erm, should have read rest of the thread before replying. :)
Exactly. It was quite common trick used in many copy protections to execute an LDIR/LDDR which overwrites itself before completion and the CPU then continues executing the newly formed instruction.
Patrik
Yes I'm pretty sure that's the case (and discussed on various forums many times before). The easiest way to think of those ...R(epeat) instructions is as a single instance of their non-repeating counterpart, but with an integrated JR -2 (= back to instruction start) when the end-condition isn't met. Effectively the same as N times the non-repeating instruction, but folded into 2 bytes.
Meaning it does allow some programming tricks that wouldn't be possible if that block instruction were treated as an 'atomic' one (read: always executed whole). Or that eg. a 40KB block copy will happily allow an interrupt routine to cut in halfway, and then simply resume where it left off. Which is probably the desired behavior! Anyway it's easy to write some testcases for this, and I'm sure they'd confirm the above.
Probably the reason for existence of those block instructions isn't speed, but code density / programmers' convenience.
Makes you realize how 'dumb' a really Z80 is :lol: and how wasteful it uses memory bandwidth. But not surprising if you consider that @ the time of its design, transistors were expensive, and memory bandwidth (or power consumption!) weren't the limiting factors they are for today's CPUs...
I guess you missed [thread=47021]this thread[/thread], then...
More helpfully, I should say that Spectaculator handles HALT correctly, and there is a HALTed flag in the SZX format. I?m not aware of any other snapshot format supporting this. I don?t know which emulators support SZX?s HALTed flag but Fuse isn?t one of them.
