Iv just fired up my toaster and it has a grey screen. I can still see the menu which still works ok. It looks as if someone has painted the front of the telly in a diluted grey colour. Any idea's please whats wrong please??
You do not have permission to view polls.
Balford means TR4 and TR5 transistors. They are at the L shaped corner where the right hand case leg is, just next to the coil.
But in order to help you, it would be handy to know if the +12V line is actually at or near +12V. If you don't fancy testing on the TEA2000 chip, test the +12V line on the edge-connector (just be careful you don't slip).
The heatsink is large, so it takes a while to warm up.
