Is Blur (DoNotTrackMe) Overkill when using Adblock Plus + NoScript
Ive used ABP and NoScript in Firefox ever since those annoying Crazyfrog ads where they played loud motorbike fart noises when you accidentally moused over them while scrolling down a page.
I also have used for a few years an extension called Do Not Track ME which blocks ad trackers. The problem is a while back the developers went all corporate and not only changed the name to Blur they also tacked on loads of other features like Auto-Fill, email masking etc which i turned off.
The only thing i use is the Tracker blocker and im wondering if i even need to use that seeming as ABP and NoScript already block a lot of chaff.
Does anyone on here know if Blur is overkill?
  • edited October 2015
    I have NS/ABP but I don't think they can block tracking cookies. There should be a few extensons that do that without the extra bloat, Ghostery seems quite popular.
    Post edited by Zoffy on
    General Malthadius Zoff
    Magenta icon
