velleman k8036 - Video signal cleaning?
http://www.velleman.eu/products/view/?country=es&lang=en&id=348080
Although velleman reports having discontinued this kit and its primary use was to remove macrovision protection I found among one of the very few reviews of this product someone stating that it also works for "normal" video cleaning.
Once it is possible to perform the composite video/ s-video mod for the spectrum, I was wondering if some video quality uprate would result from using this kit. :-?
Anyone has tried this before? Any thoughts? (Is that a LM1881 I seen in there?)
Post edited by Renegade on
Yes an 1881 chip is part of the schematic to separate synchron signals from composite. This is necessary to mask the macro vosion signal. A 4066 C-MOS switch is used for a sample and hold circuit to cut of macro vision signal. There is no need for such circuitry to improve the Spectrums video signal.
Ingo.
Thanks, I saved some money this time. ;)
