I'm afraid this was before the days of Skoolkit, so it was all running on an emulator and writing everything down. So I'm afraid not.
You used to have a disassembly of Pyjamarama on your site, though. Where did it go? There's still a (broken) link to it on this page.
You know what the memory aint what it use to be, but I thought there was one. But it's not on the site (had to wipe it lately) or on my local mirror, nor in my 'work' folders. Maybe it is on a drive somewhere. Worth a look for alienbanana. Was it Skoolkit dump, I wonder?
>>I can't get it working.
>>Here is a dropbox file of it if anyone would kindly have the time to look at it.
Are you using a debugger yet?
It will make it a hundred times easier to locate the problem, rather reassembling after every change; or staring at source code.
<Very late>
Yes, it was done with old version of SkoolKit (2.2.4 or earlier).
If you can't find it or the source files, I have a copy of the HTML files dated 2011/08/25.
SkoolKit - disassemble a game today Pyskool - a remake of Skool Daze and Back to Skool
You don't really need a dissassembly of something else - just put some thought into it and concentrate without stopping up every 5 minutes asking why it doesn't work.
You also need to make sure your sprite routine will now work with C,B,DE not D,E,HL.
https://www.dropbox.com/s/iykkfdj6620575b/variabletile.zip?dl=0
the actual masked tile print routine is by Adrian Brown. Thanks everyone :)
Everyone has a crap game inside them, let yours out!
Take a look @ luny.co.uk/pyjamarama/index.html
