Smart platform-action games?
2
  • mityay wrote: »
    Lode Runner?
    There's hardly any thinking IMHO. You basically need to be quick at digging holes on the ground when an enemy gets too close.
  • I agree it's a great game, but it's not "smart" either. It's more like a combination of graphic adventure ("find item A to pass through obstacle B, then items C and D to pass through obstacle E, etc") and action game (avoid enemies when they appear).
    Sorry, I see the distinction, my mistake. I can't think of any Speccy games that suit your description and haven't been mentioned. Brian Bloodaxe does require some planning (for example you only get a limited number of bullets in the gun, you have to judge what things to destroy with the bombs, and using the objects-float-in-the-air-where-you-drop-them game mechanic you can build staircases/platforms to otherwise out of reach areas. But Retrobrothers already mentioned it (the cheating git!).
  • Fahrenheit 3000 required a lot of planning but it was waaaay too hard
    OK, I checked it. IMHO it's an action game that requires tricky jumps, to be learned by trial and error. It doesn't really require much thinking.
    It does require a LOT of swearing!
  • stupidget wrote: »
    For the speccy Automania was a pretty good take on the platform game
    In Automania there's no thinking at all. Collect car parts from one screen in whatever order you want, carry each one to the other screen, jump over enemies along the way.
  • Crikey you're a tough customer!
    Has anyone mentioned Fran N Stein yet?
  • Knight Lore, Head Over Heals, Alien 8
  • Not what you're asking for, I know, but in games where you get a points bonus based on how quickly you complete the level, then if you're using an emulator (or a real Spectrum but with a Multiface or other snapshot based hardware) then you can play the same level as often as you like, refining your pre-chosen on-screen route, to get the highest score on that particular screen.
    So with games like Manic Miner, and Chuckie Egg (both of which award you points according to how quickly you complete a level, and have no random components to render the idea pointless), you can pre-plan the quickest way to complete a given screen, and then see if you can find a quicker route to do so.
  • There is Tarramex...
    worldofspectrum.org/infoseekid.cgi?id=0005195
    It's very heavily puzzle based, needs a decent effort to figure everything out, and is a fairly entertaining game. I remember completing it as a kid and feeling really chuffed with myself :D
    There's also Dizzy - have you completed all the Dizzy games?
  • ewgf wrote: »
    Isn't the Solar Power Generator random? It certainly seemed like it when I did a run through with snapshots a couple of years ago.
  • hikoki wrote: »
    These are all graphic adventures.
    In a previous post I provided the rationale to distinguish between smart platform games and graphic adventures. I believe this rationale matches our common sense. Dizzy is obviously a graphic adventure, Frank'n'Stein obviously isn't.
  • I just realized that SIP and Gravibots (both by Denis Grachev) are also smart platform-action games!
    True! But if it was an easy question, I wouldn't have to ask!
    So far we have identified quite a few Speccy games in this category:
    Frank'n'Stein
    El Stompo
    Alter Ego 1 / 2
    Solomon's Key / Spherical
    SIP / Gravibots
    And also Braid in modern platforms.
    There are a few other games people mentioned in this thread that I didn't check yet, I will reply later. Thanks a lot for all suggestions!
    Yes :)
  • edited May 2016
    How about Frost Byte?
    It's a thinking puzzle game with platforms in it.
    Sticking with the 'cold' theme - how about Mr Freeze? It's a crap game but perhaps it kind of fills your criteria?
    <Clutches at nearest straw> :)
    Post edited by Retrobrothers on
  • edited May 2016
    This was promising : http://www.kongregate.com/games/Againsthelaw/hereiwas?acomplete=hereiwas
    It looks more like a demo, unfortunately the author didn't go beyond the initial idea, but has action as for performing the jumps well and it has a wtf feeling at the start of some levels.
    Post edited by hikoki on
  • leespoons wrote: »
    ewgf wrote: »
    Nope. The beam changes direction when it hits the mirrors on the nasties. And since they're predictable, so is the whole screen.
  • Cauldron II - The Pumpkin Strikes Back is a very strategic platformer.
  • edited May 2016
    I would have to add in the vein of Frank 'N' Stein:
    Ralph on Alpha2 which was on 16/48
    (and I guess therefore also add Colin the Cleaner from good old Harry S. Price )
    Post edited by aktiv8 on
  • aktiv8 wrote: »
    I don't think this is a smart game. Once you learn the "illogical rule" that the hero can easily walk upstairs, but dies if attempting to walk a single step downstairs, then solving all levels become trivial.
  • Ersh wrote: »
    This seems to be a pure action game, based on making tricky jumps.
    If you can collect those "magic sparkles" in any arbitrary order, then it doesn't quality as graphic adventure either, just platform-action.
    Perhaps I'm missing something?
  • retromad wrote: »
    Other Speccy games?? thinking of my own collection....'Stormlord' comes to mind...
    http://www.worldofspectrum.org/infoseekid.cgi?id=0004922
    Stormlord also looks like a graphic adventure to me...
  • hikoki wrote: »
    Would Bubble Frenzy qualify ? :)
    Yes!
    In Bubble Frenzy, each level requires a different strategy to win, that is not immediately obvious at the start. If you make a wrong move, you will dig a hole that will block your own access to the next teleporter. Thus you need to plan your path carefully... although the fast action doesn't give you much time to do it.
  • I wonder if 'Bounty Bob Strikes Back' qualifies... it's a platformer and easy levels could be solved with brute force, but later on things get tricky, and you need to plan an effective route or you'll just fail... which platforms to walk over and when, when to grab an item and which enemies to kill with it, how to walk over all the platforms without getting stranded. Damn it's an infuriating game but I keep coming back to it, much like Frank'n'stein.
  • hikoki wrote: »
    Yes!
    I haven't played Bubble Frency much but if there are foes who follow the player you may end up in a mess of aisled platforms so you'd better plan what and when you break with your hammer.
    Gabriele Amore has another interesting game mechanic in Albert the Wolf, where you can build your own path by laying bricks in mid air. I don't recall why controls of this game failed for me.
  • Kickle Cubicle on NES, unappreciated game, love to see Speccy port :)
    https://youtube.com/watch?v=DLCXAqMqp-k
  • Does Bomb Jack count? A well-planned route gets you the maximum bonus from the fizzing bombs.
  • I also wondered about Bomb Jack.
    How about Gilligan's Gold?
  • This seems to be a pure action game, based on making tricky jumps.
    There's actually a little less action than one would think, every room is like a slow puzzle and you have to methodically plan several steps a head to get in to the right position to achieve what ever you're going for. Pause and plan, execute, pause and plan and so on. It's all about finding a setup that'll work towards your goal. If you make a mistake you'll have to rethink and try to salvage the situation. I think the game is so misunderstood because, perhaps, most players treat it as a pure action game and just bounce all over the place firing their magic/health all over the place without any real plan. Which is a quick way to get killed. But when you sit down and use some strategy and finally 'solve' a room you'll feel pretty good about yourself.
    You can pick up the 'magic sparkles' whenever as they only serve to refill your health and give you the ability to shot. Though figuring out which 'sparkles' to leave for later is key when planning your route through the castle, and there are several you can take, some harder/easier/quicker etc.
    The items you pick up are used for different things; the 'axe' to get through doors, the 'goblet' will allow you to touch the 'hands' without getting your inputs reversed and so on. Which order you pick them up in depends on where you start and how you've planned your route.
    That's my opinion at least. :)
  • How about Gilligan's Gold?
    IMHO the route you take in Gilligan's Gold is mostly determined by enemies that move randomly, thus planning an strategy is not much possible.
  • SwitchBlade and Turmoil spring to mind.
    Chuckie Egg?
