NASA Mars Rovers faked?
1356
  • Also, regarding the Moon landings. The Rover's batteries couldn't have worked on the Moon according to the specifications of the Moon Rover. The average temperature is 107 degrees C. Maximum working temperature for the batteries was less than 60 degrees C. How?
    The family photo left on the Moon by an astronaut and photographed on the Moon is perfectly flat. But if exposed to temperatures above 100 degrees, it would curl up after only a few seconds. A photo is like a bi-metallic strip under heat. It will curl into a tube in no time on the Moon.
    The iconic first footprint photo on the Moon is also an obvious fake. Fine dry dust/sand cannot make such a defined footprint. Only wet sand can give that kind of definition. Sharp 90 degree edges aren't possible in dry sand. Water cannot exist on the Moon.
    It's all about the money, and funding. Raping the public purse.
    Thanked by 1redballoon
  • China landed a rover on the Moon last year. The second picture released appeared to show a step pyramid on the Moon. They announced they were going to investigate 'the pyramid', and we never got another image from China since.
    The Chinese lander, landed within 300 feet of the pyramid. And the Bunny rover headed straight for it.
    Now we get nothing.
  • edited June 2016
    FrankT wrote: »
    There are answers to all of those points in numerous places over the Internet. Did you bother looking them up? Or do you just accept the first thing that some conspiracy twonk tells you? Do you believe you are special in some way? More intelligent than the 'sheeple' who blindly swallow everything that NASA and the 'mainstream media' say?
    Post edited by Dave_C on
  • Dave_C wrote: »
    I don't believe the laws of physics are different on the Moon or Mars. I believe they are universal.
    There are hundreds of Moon photos that are obvious front screen projection fakes. You can see the difference in texture between the foreground and background. The line is obvious. Not to mention the same background used on pictures from different locations.
    It's fake.
    The NSA have the real space program and it's private. NASA is just there for the public to accept 100 year old technology is the best we can do. 2 trillion dollars in one year for the private 'black' projects in USA. NASA doesn't get that sort of money.
    Just look at when technology is released to the public from these private 'black' projects. Recent disclosure shows that the B2 Bomber was first flown/tested in 1948. Public never new about it for at least 40 years.
    Quasi Crystals were first developed in 1972. A whistleblower guy named Edgar Fouche spoke about them being used on black project aircraft. Yet the first public patent was 40 years later.
    40 years seems to be the average time between, something being developed in black projects, before being released to the public.
  • edited June 2016
    FrankT wrote: »
    It's fake.
    It's real.
    FrankT wrote: »
    WTF are you on about?
    FrankT wrote: »
    Well I guess if some guy said so after the fact with no evidence then I guess there must be a gigantic conspiracy unless someone can prove it's not true!
    Post edited by guesser on
  • edited June 2016
    Dave_C wrote: »
    FrankT wrote: »
    Dave_C wrote: »
    So no then, you didn't. You know f*ck-all about the laws of physics, and THAT is a fact.
  • Dave_C wrote: »
    ooh, the heat just turned up a few notches there! :)
  • FrankT wrote: »
    Genuine question - are you a photographic expert? Can you prove they are fake? Y'know, real proof they are fake?
    Are you also aware of JPEG artifacts?
  • edited June 2016
    def chris wrote: »
    Dave_C wrote: »
    Apologies, I have a low threshold for bullshit. :(
  • redballoon wrote: »
    Of course... He has a phd in space weathering and mineralogy too, that's how he knows it's impossible to make boot prints in lunar soil... :p
  • now where did i put Boozys popcorn
  • Sh!t. I just accidentally thanked FrankT while scrolling up on my phone.
  • Try to keep it nice and remember crazy people have a right to say stuff too.
    My test signature
    wibble f3rr3t teeny weeny weetabix wibble wibble ooh matron
  • Frank, can you explain more about the chinese rover bumping into a menhir?
    Also let's build massive centripetal gravity all around the moon so the chinese can have a colony there to work hard as astronomers.
  • The real question is, what crash landed in Arizona this morning, and is it connected to the space squirrels in some way? 8-}
  • FrankT wrote: »
    If the official NASA photos are to be believed, there is a living Lemming on Mars, which appears on one photo, and not on another taken of the same area at a different time. A sea creature fossils on rocks. And a man's shadow leaning over the rover to clean its panels when it got too dirty. There are a couple of photo's of men on Mars cleaning the Mars rover panels now.
    And the reason the man's shadow is bigger than a regular person is... it's not a man, it's a Bigfoot!
    NASA prefers to hire them instead of normal people because they are less likely to get caught. I guess NASA wants to hide the fact that a Mars mission isn't really viable because the Mars planet is flat, just like Earth.
    Everything was filmed at a secret location inside the Hollow Earth. If you magnify this image, you will clearly see a crack on the Hollow Earth ceiling in the top right corner, just above the Loch Ness monster head.
  • edited June 2016
    FrankT wrote: »
    " LRV batteries and electronics were passively cooled, using change-of-phase wax thermal capacitor packages and reflective, upward-facing radiating surfaces. While driving, radiators were covered with mylar blankets to minimize dust accumulation. When stopped, the astronauts would open the blankets, and manually remove excess dust from the cooling surfaces with hand brushes."
    Simple
    Post edited by murtceps on
  • I hate it when science gets in the way of a good conspiracy,,,
    btw this should silence the naysayers, chief engineer of the Curiosity rover team clears everything up about the mars landing process at 36:10 on this vid
  • I like how nothing has ever been to Mars, but you're quite sure you know how strong or weak the wind is to offer your opinion on how much dust it could move. Brilliant.
  • joefish wrote: »
    Ooops.
  • Why does WoS attract freaks and nutjobs?
  • def chris wrote: »
    36:10 on this vid
    Jeez, who the hell put Elvis/The Fonz in charge of a frickin space mission! ;)
  • karingal wrote: »
    And then I make them admins! D'oh!
    My test signature
  • karingal wrote: »
    Phew, I thought you were talking about me for a moment, then I remembered I was already admin...
  • Dave_C wrote: »
    def chris wrote: »
    Dave_C wrote: »
    Brilliant!
  • Like most people here, I really really really want the Mars exploration missions to be real & genuine, so this "hypothesis" (And it IS only a hypothesis at this stage, not an actual allegation yet), deeply disturbs me... It also deeply disturbs me that while the hypothesis being put forward is quite detailed, much of the responses here in this forum have amounted to little more than ridicule and insults rather than serious counter arguments... Unfortunately, and admittedly, there may be few people here (I count myself also, of course) well qualified to really provide counter arguments that can sufficiently put this to rest... It doesn't satisfy me that this issue here seems to rest solely on the matter of faith as to whether one should "believe" NASA or not... In my mind these are seriously dangerous ideas... The plausibility of the hypothesis disturbs me the most... Personally speaking, despite the unpleasantness of this hypothesis, I would like to see people take up Rich's challenge, and go the extra mile to provide, if they can, concrete evidence that nails this hypothesis one way or the other, permanently... Like Dunny said, if this is JUST a theory, then it will ultimately pose no threat to the truth... but if this hypothesis does hold water, then I for one would appreciate evidence gathering to bring us closer to the truth... At the end of the day, I don't believe this should be a question of conspiracy theorists Vs Official-story-believers, but rather a question of open minded people who simply want to know the Truth, whatever that turns out to be...
  • edited June 2016
    Give me a break. Conspiracy f*cktards are the most closed-minded people on the planet. No amount of evidence presented to them will change their opinion. They like to feel 'special' and see themselves as being above the 'sheeple'.
  • Really? The question should be "Why would NASA make it up if it didn't happen? What reason would they have for making it up? If they didn't travel to the Moon or Mars or whatever then what are they spending the billions of dollars they get each year on?" Sorry, but they conspiracy theory is just that, a theory and no more than than that.
    The journeys to the Moon and Mars did happen, the evidence to prove they did is overwhelming.
  • The problem we have here is that you get comments saying, for example, the moon landing was faked and it's obvious from the photos because of this and that. You then get experts who debunk all these claims and the result? They're either in on the conspiracy or they're ignored. This isn't new. You could argue could be the same from a conspiracist's side, but the evidence from that side is so hokey and is pretty much disproved through science and physics.
    The whole lemming/rock issue is just the same. The brain and mind is an amazing thing but fundamentally flawed. It sees shapes and patterns in everyhing to help us fill out the blanks/gaps that we can't quite comprehend. And it will fill it in with something we can.
    Anyway, it'll always be a Reservoir Dogs style stand off, so there really isn't much point arguing or providing evidence. We've pretty much made our minds up anyway and it's unlikely that will change. In the meantime, I'll read in for my own entertainment.
