Buying a new TV
My Philips 9 year old flatscreen TV is on the road out and recently wouldn't switch on (and the picture is starting to go) so I think I need a new TV.
I've had a look online but there's so much choice - do I go for 4K? A Smart TV? LED? Plasma?
To give me an idea, what kind of TV's do you have? My budget is going to be around £300 - £350.
Forget the curved screens...gimmick.
ebuyer.com are always worth keeping an eye on. For example they have a 39" 4K (not Smart though) for £190. They generally have at least one decent deal per day so it's worth subscribing to their daily email. I've got a "no-name" 42" LCD (Foehn & Hirsch whoever the hell they are) that I got from ebuyer in 2009 and it's still going strong so don't be swung by it having to be by a big electronic manufacturer.
Smart? Perhaps but there's so much choice it's hard to choose. I'll not bother with curved or 3D either, a waste of money.
http://www.worldofspectrum.org/forums/discussion/45947/hd-tv-recommendations-please#latest
I'd recommend going to Currys or summat and have a good look at the picture quality. That's what we did and there was a massive difference in quality of some of the different makes. Make sure you check it's got enough inputs. It didn't matter too much to us (HDMI switcher and 2 scart boxes) but it may to you.
Also Richer Sounds also are good as a lot have a 5 or 6 year guarantee.
For some reason, TV manufacturers seem reluctant to specify if a given TV of theirs can display the low resolutions or low frame-rates of of pre-PS2 consoles, and even if the TV does display the console output, some TVs do so very badly, with blurry or flawed pictures.
TV's on sale described as LED, are a bit misleading. This is only referring to the backlighting used to provide the light source for the LCD screen. The cold cathode flouresent back lights are plenty good enough.
Also, if you are checking the picture quality, don't forget to test the sound as well. Some of the "thin" sets have not very good speaker systems :(
Mt Visio is a smart TV which means I can do netflix or youtube without a computer being connected. I can also use my mobile phone as a keyboard for entering stuff on screen.
Did you know that most LCD TVs just have a crappy power source, which is what goes bust, because they place electrolitic capacitors, near heat sources, which in time, dries the capacitors, and makes the power source malfunction or not work at all.
But the good thing is, you can recap these power supplies, with less than £10 in parts.
If you open it up, and capacitors, look fat or bulgy, on top, just replace all electrolitic capacitors, and you have a refurbished TV in no time.
Note: Your mileage may vary, but sometimes there are other problems.
However intermittent power failures, is usually related with bad/dry capacitors.
P.S.
I fixed my parents Kitchen bench TV, with exactly this problem, just last month
I still have a hitatchi from portable from 32 years ago, but it didn't get loads of use after the spectrum.. probably why it lasted
http://www.argos.co.uk/static/Product/partNumber/3979877.htm
I regard a "smart" TV as anti-feature. The software will go out of support in relatively short order. Just compare with say, many Android phones on the market. Perhaps 2 big/important system updates, 3 if you're lucky, and after that (warranty expired ;) ) you're on your own. Swiss cheese security-wise? Tough. At best the 'smart' features won't get in the way @ that point. Oh, and that's ignoring vendors-spying-on-their-customers, NSA backdoors or whatever. X(
I might be in the market for a TV myself in the near future, my wishlist is short:
* Biggest I can fit on my desk / corner of my room. Big is cheap these days, and screen real estate is something you never have enough of.
* Full HD (1920x1080) minimum. And probably just that. I just don't care about higher resolutions when broadcasts / movies etc in those resolutions are still rare, and Full HD is more than good enough for my uses. By the time that has changed, time for a new TV...
* Lots and lots of inputs: analog RGB (SCART), composite, VGA, HDMI. Preferably >1 of some.
* None of this "smart TV" bullshit. Speakers optional as long as there's sound output signal(s) to be tapped.
soldering ... sorry dad.. (oh look it's even later ;-) ) . I keep late hours anyway, get far more done.. well until they start PPI calls at this time.
besides my idiot neighbours like making excessive noise till 3am.
nice tv, and if it's cack just bring it back within 2 weeks argos are good like that. I'm after a tv for a kitchen, it's annoying that the 5487935795" tv's are the same price as the 22" etc
I'll decide later today, when I get home and order it.
The TV that I have is a well known make. But even so, within the first six months, I needed to contact the manufacturer because it stopped receiving digital tv transmissions. I had to use my PC to download an "update". Transfer it to a USB memory stick, then go to the special settings "screen" just to get back digital tv!
So you can take your "smart" whatever and shove it in a skip.
It's really nice, has great picture and good (but not great) sound.
If only it would connect to my wi-fi - the router is sitting about 6 feet away from the TV :))
Does it work with your Spectrum via the SCART socket and is it a great picture?
(providing you have a real Spectrum and it has been wired up to use the SCART socket.....)
All round to zx1 gaff to watch the TV and help him annoy his next door neighbours.
*tells all the wossers to come round to watch the rugby and get the beers in*
we better hurry up, and don't forget our passports.. hehe . I didn't realise JK Rowling was a member of parliament like a load more celebs / writers etc.
"oh I've missed all the free pizza"... what a shame :D
This is true. But it's becoming more difficult to find non-smart TVs that aren't lowest end in terms of picture quality, connector numbers, etc.
Also spent some time fiddling around with the internet options such as Youtube etc. The interface is a bit fiddly and will take time to get used to though.
I've also just realised the stand swivels so you can adjust the viewing angle, that could come in handy.
