PC Internet connection
Over the last few days i've noticed a problem with my internet connection, i notice that if put the PC into 'sleep' mode when i switch it back on my internet connection is gone, a troubleshoot test showed that 'there may be a problem with the LAN adaptor' so i found a spare ethernet cable and changed it but the same thing happened. If i restart the PC my connection is back. The router showed no problems and as far as it was concerned the PC was connected to wondering if it may be a software issue? Any ideas?
And yes, the ethernet card is a Realtek model.
My workaround is not to close the lid. :P
...So if you find a solution, let me know as I'm too lazy to look...
Also, there are a tab called Advanced Options, that show some properties that can vary from device to device. I've got a Realtek network card, and there are some options related to energy saving (I've seen those options with different names on Intel adapters, so the options on your computer can be different).
If everything else fails, check if there is an update for your driver. I had some (branded) computers that didn't dropped ethernet randomly with their drivers, but after getting an updated driver from the network card chipset manufacturer (i.e.: Intel driver instead of HP) they worked well.
BTW, NEVER trust in any "updated" driver downloaded through Windows update. Use only your manufacturer drivers or chipset manufacturer driver.
An' you know what they said?
Well, some of it was true!
