Satan from Dinamic gets stuck at the end of the second load
Hi friends, doing a longplay of this game I used the files from this site. The most of then seem to have a bug, but I'm not sure if is an emulation bug or a native bug. I've played with the mame and zxspin emus and basically, when you destroy the last flying demon damien, the final message doesn't appears, and the countdown is still running until it reaches zero and you loose the game...
The only file that worked fine was one included in one compilation, but I don't remember which one I played.....maybe Megabox 1, 2 or Metal Action...So I want to ask if somebody played this game in a real spectrum, and if this behaviour was here...
Post edited by StHiryu on
Then again, RZX archive has only part 1 of the game (which is the most difficult by far) and there's no recording of part 2 in youtube either.
I owned the UK release at one point and compared it against the other versions in TAPIR to double check whether my TZX conversions were good.
There are basically 4 variations so it is possible that they revised/fixed any potential bugs in later releases (most likely when re-issued on compilations).
(1) Original Spanish release using Dinaload.
(2) Metal Action release which uses Dinaload and is also in Spanish but has a lot of differences data-wise according to TAPIR.
(3) System 4 (small case) release = UK release = Megabox version = Megabox 2 version. More of a standard type loader with a few headerless blocks. In English.
(4) Six Appeal = Different loader again and also in English. Standard loader with all of the game data in one big block.
I don't know if that's of any help but since you mentioned that "the only file that worked fine was one included in one compilation" then that would seem to me to indicate that there is a bug in at least one of the releases that was later fixed.
I tried it once, a few years ago and failed :)
I remember it was very weird, you walk in some empty environment, searching for some single enemy that you have to defeat.
Rarely you find him but after giving him some beating he changes his form and you have to search for him again.
And then it's TIME OVER. That's what I remember.
Satan Spectrum Longplay Retro Danuart
I submitted it to Rzx Archive, it should be available soon.
Unfortunately it plays badly. The scrolling is very bad, the game is slow and the graphics are overdetailed so it's hard to see anything.
But I did it! ;)
Ralf: Finally yoy get the message? What file did you used?
