What should your speccy have come with ?
I was thinking about this earlier. What changes should of been made to the Speccy when you purchased yours ?
Realistically this topic really only works properly if:
1. You purchased a machine (either new or used) 'back then'
2. You are sensible in what you would suggest, so no 2mb ram given the cost
3. You can only add things that would of been semi-sensibly possible at the time.
4. Try to keep to a sensible margin of price changes.
OK, I'll *ahem* try mine including the IF.1 too:
I purchased my 48K new in 84. My suggestions would of been:
A reset button should of really been included in the rubber keyed model
A power switch (mains) in either the flexible lead or a rocker switch in the PSU 'brick' itself
System variables (two bytes maybe) to change the tape baud. I'm not thinking here of the BBC Micro 300 vs 1200, I'm more thinking a POKE to change it to say 2000 or 2500 or 3000 at a push. Obviously being in the Basic etc it could be changed at will so useful for games etc.
Interface 1: I recall it was intended as a 'serious' upgrade but if that's the case where is the video out on the IF1 ? I realise the signal is on the edge connector and (imo) a 'serious' user may well of had a monitor so not including this was a shame.
Shame Uncle Clive did not use a 8271 (even though its a 70's chip but the 1770x was not around in 82 I think) in some kind of IF3 to allow a 'normal' drive to be used, even if it used Microdrive commands.
Talking of IF1: A bit more in the network capability would not of gone amiss. Perhaps (BBC Micro style) some kind of pins to select a 'station' ID in the IF1 so it was permanently set.
I no doubt have other thoughts but I've forgotten them for now. :)
Please visit the JetSet Willy & Manic Miner Community
It was great for teens and grown ups,
I needed something more dumbed down, like a small tutorial on how to make a small game.
However, a three pin header/PCB connector carrying +5V, composite video and 0V/GND on the PCB would have been good. Then either Sinclair or a third party supplier could have sold plug in composite video "adaptor" module kits.
[The +5V would allow another transistor to buffer the composite video output if required]
But, with the ZX Spectrum+, I think Sinclair missed a trick or two. It should have had built in composite video output socket (phono/RCA type), joystick ports and a built in cartridge slot. If the joystick ports had been wired in parallel with the keyboard matrix to the Sinclair standard, the cost would only be that of the extra PCB area and the two 9 pin D plugs, plus maybe some diodes. The cost of the cartridge slot again would only have been PCB area and the cost of the edge-connector.
Oh and when the price of 64k bit DRAM chips fell, so that there was little difference between 32k bit and 64k bit DRAM chips, Sinclair should have upped the memory to 80k bytes (16k + 64k with the top 32k in four pages of 16k). Maybe called this the ZX Spectrum 80k+.
Yes the Timex 2068 was a good machine, I'd rather have mine back than the original 48k Speccy much though I loved it.
Its nice to see what varying opinions on what (could) of been sensibly done.
Yep!
A faster (more efficient) BASIC overall would have been nice.
A slow down time lever on the side. Time seemed to speed up whenever I sat down in front of my Speccy. There was never enough time in the evening.
The diode, I agree with. At the time (1980's), a lot of the devices I had that used mini DC "barrel" plugs was around 50% used positive outer / negative inner, with items intended or which may often get used in cars etc having the other polarity. With some devices, part of the reason for the manufacturers to have a particular polarity is due to the way the switch contact works. It's related to switching the internal battery in said same item... Yes, I know the Speccy has no battery... Just saying...
Specifically if a woman?
"Show me some more of these earth thing called kissing"
Also agree with Slenkar, a decent intro guide to BASIC programming that was less of a reference manual might have been good. It was fun to learn from magazines though.
I always thought the manual was excellent - I remember a comment in Computer Choice to the effect that it was worth buying a Spectrum just to learn BASIC.
I would like to have seen:
A sound chip - multi-channel sound, or any way of making sound that didn't halt the whole system. Or at least sound through the TV!
High resolution colour - no more attribute clash.
However, both of these limitations were overcome.... Zombie Zombie and then Vectron, Gyron got extra colours using interrupts, and even YS published a hi-res colour routine.
I've always felt that the inherent limitations of the machine inspired programmers to achieve the 'impossible'. Not a bad thing.
Been waiting for someone to say her, Sam Fox or some other lady from the Sun.
