Spore - bug after level 11
During my work on database with marks (ratings) for all Speccy games, I've just found that in game Spore (Mastertronics) after completed level 11, game cannot setup next level so player advances to next-next level (only with loss of 1 energy point). When you reach (and 'pass') level 40, game says: "You've completed all levels".
Also, "smart bomb" doesn't work (from level 1), it should be activated with pressing "Space" but nothing happens.
I've tried both TAP and TZX versions.
Can anyone look into code, and try to bug-fix it?
P.S. Spore, yep, that meansI'm finishing letter "S" :) there is 2720 games in database already, soon to start work on "T".
Post edited by Alex_Lux on
Next time I will check the smart-bomb problems.
Pgyuri
However OP mentioned a problem after completing level 11!
Are there 10 or 11 working levels in this game?
After finishing the last complete level, the "WELL DONE! YOU MAY PROCEED TO SECTOR 11" message appeared, what was nothing (not empty, filled by wall) and then happened what Alex_Lux wrote, stepped level after level to 40th.
Pgyuri,
thanks for info and your effort!
Thanks for the clarification! I will add a "known bugs" note about this game in ZXDB.
I suppose it's possible to edit levels 11 to 40, then play everything normally? If so, them leaving dummy levels isn't so bad...
Please let us know!
smartbomb = pills
So checking the code, this is absolutely unfinished part. The game scans the keys but 2 keys has no checking routine. One of is the key 'A' (maybe abadon game) and the second is the 'SPACE' (should activate pills as is written in the inlay text).
First I thought there is no pills activate. To see the deep code, found pills mode could be work if activated with some special POKEs but the handle routine is bugged. It is longer (and many POKEs) to make working.
Will make as soon as possible.
This game is absolutely unfinished. For example the interrupt routine check the Caps Shift key but not handling (just a NOP and NOP) maybe for PAUSE mode. In the menu the game is starting only pressing by 0 key but checking and dropping the SPACE key status.
Hmmmm.....was not fair in ....
Pgyuri
If the editor cannot be used to directly replace the missing levels without some hacking, then these missing levels are pointless and it would be better to eliminate them. Preferably changing the game to finish after level 10 instead of 40.
Unless Alex finds the missing levels in the C64 version and someone can port them...
The correction is complex due to many bugs. If anybody interested in, see Multiface (or emulator) repearing:
$CDF9, $27 $CDFD, $00,$00,$00,$00,$00,$00,$00 $CE1D, $00 $D103, $90,$8C $8C90, $DD,$CB,$2A,$7E,$C2,$EE,$E0, $DD,$CB,$20,$76,$CA,$EE,$E0, $DD,$BE,$2F,$CA,$EE,$E0, $DD,$CB,$2A,$FE,$C3,$EE,$E0Then after collecting any pill, the SPACE can activate one and good to see how the spores run away.on Youtube you can watch C16 version completed, you'll find out that levels are same, but there is only 10 levels and game end with (correct) message - You have completed all... blah, blah.
C64 version seems to have more 'bugs', there is hack with option of unlimited energy, I try to use it, and... after level 8 game started to behave as Speccy-bug i.e. to advance levels after 1 second display (always showing last played layout, i.e. level 8 in my case). OK, I try WITHOUT energy cheat... now after level 6 same happened :) :O just to mention I used same emu, same controls and same file.
Finally I tried another emulator and same (advance/skip level-'bug') happened after 5 or 6 or 7 level, I just gave up, not noticing which one.
So there is only hope that CPC version is maybe finished. I don't have CPC emu, and don't even know is there at all a copy of Spore, so it's a task for someone else. For me, this case is closed. Game status = unfinished.
The Spectrum Computing site doesn't display the "known errors" information about games yet, but hopefully soon...
