Redefining Keys
wondering if there is any way that keys can be redefined in games that don't allow it (E.g Hunchback 1).
(at the minute, it is some crazy config like Q=left - not sure of others!!)
i normally use Spin or Spectaculator for emulation, and find that if you could redefine your own keys like most other emulators it would be a vast improvement - can this be done?
[ This Message was edited by: SpeccyLover on 2005-07-22 23:22 ]
Post edited by SpeccyLover on
Hit each direction button in turn and tap the key that you want it to correspond to.
When done, the cursor keys and Ctrl will work as the keys you've set. If you don't like the cursor keys then you can use the "customize" button to change them to whatever PC keys you like, in a similar manner to the "Define Keys" option.
Whilst playing the game, press F7 or use the small "keyboard" icon on the toolbar to activate the keystick.
[ This Message was edited by: Dunny on 2005-07-22 23:43 ]
If you set your keystick up, start hunchback and find that it don't work... Quit SPIN immediately (don't end the task, use the quit button) and then find your SPIN.ini and any *.spincfg files. Attach them to an email to me, and I'll take a look.
QAOP space is the best
but
QWPL SPACE would be second best
better than those crappy cursor keys anyroad
Cursors work for me :) (Don't have to think about them, they feel natural)
were talking about emulation on a pc arent we?
I would prefer QAOP + Space or CURSORS + CTRL.
Perhaps my paw differs from yours somehow :)
