Vapourizing Tracking on top side of 48k Speccy Boards.
I think I used a hot soldering iron and it caused the tracks to disappear on the top side of two Spectrum 48k boards I was renewing the capacitors on.
Has anyone else had this problem? Is it a known problem or am I imagining it!!
A few Spectrum game fixes.
Yes that is what I thought , it does not make sense after all I have been working on the other side of the PCB which should remain cool . So on the face of it it does not make sense
Possible explanations
1) I have got it wrong , something else is happening or the boards are slightly different etc (the General Ignorance explanation)
2) Oxidization setting it up for vapourization later when slight heat applied
3) Lack of protection on the top side
4) Leaking capacitors
5) A combination of all the above : the hybrid explanation .
It would be good if I could find some before and after pics.This explanation will be a work in progress as I think "something is up" (even if it is just me trying to overcome General Igorance!)
Symptoms.
A grey powder where the vias were . This is easily rubbed away and does not conduct It appears to follow the old tracks though
I think I have got a possible reason . My unorthodox using of a needle to clear solder holes . Maybe this transmitted an unusually high level of heat on the upper side and reduced up to half inch of tracking to a grey powder whilst leaving the underside totally unaffected
https://photos.google.com/share/AF1QipPiz92qti_Qo-D2EVUX8N-nVZOBdeaK2drl9-EeZyW3XcGb_kO2LLQVsw9D867BhQ?key=czN1QXAtbnA3amotUU4wWXlVR1U4VUFSSkYyd3V3
The cap has been upended . The hole to the right of c65 shows the tracking still intact from the empty hole . The "after" pic has not yet been taken
Subsequent examination under the microscope shows the tracking still there but in greyer less shiny form than other parts of the board and the comparison board .Conductivity is still there
I was probably panicking as it was not working (panicking is not good!)
The second pic is from a comparison board . Under the scope they look similar but to the naked eye...
Me trying to find the wrong explanation for why it was not working
https://photos.google.com/share/AF1QipMdZ3sVyK6DRlrjTR6NFlJXhFu3iY9ZqMQPK_VhtpogMFXU_3zCUK1vAmLqVcWQhw?key=NkxyT0lyeFo1UH
doNldUUm9zOXZBSlBRWkFtdjJ3
The bad repair on the hole is not the cause . By then I had redone it a few times!
Here’s a method for clearing vias I learned from an old and very experienced engineer a few decades ago. Sharpen a match (or just use a toothpick), dip it in a molten rosin, and let is soak for a few seconds. Then heat up the via until the solder melts, and use the toothpick to poke a hole through.
Of course, a solder sucker works better, but it might delaminate the traces, in which case, use desoldering braid. Oh, and don’t forget to reflow any joint with fresh solder prior to desoldering.
Thanks for the tips Yes lifting pads has been a problem .For me its " Back to the drawing board......"
