The best spyware program?
As i have a new PC i'm getting tired of Spyware Terminator so i got rid of it, does anyone know a decent spyware program to replace it? Mind you i have Malware bytes and Zone alarm so perhaps i don't need a spyware program.
You do not have permission to view polls.
i also use Avast AV
and Comodo firewall, went off zone alarm years ago
These programs slow down your system when running do it's about maintaining a balance.
Ahem.
Oh yeah, and I run a Malwarebytes scan now and then but thats never found anything more threatening that the odd tracking cookie.
Magenta icon
Are you sure you're not me?
Shhh... don't tell anyone...
Especially yourself!
JSpeccy-win32-portable
If anyone is using an XP machine, then Sophos say they don't support it, but can - and Kaspersky updates still apply to v6 - 8, which work on XP. Just thinking that a lot of you probably have old PC's with floppy drives and stuff for the sake of compatibility, or writing discs, or old software that you rely on that hasn't been updated in decades.
Boozey, try Geek Uninstaller. It cleans up a lot more than the standard uninstallers and I had to use it once to remove all trace of McAfee's crapware.
