Bomb Jack issue
So i came here to get my all time favourite... Bomb Jack
I got the emulator, i got the file, the game loads fine but and when i try to do that super jump with "X" and "Q" (at the same time), the special jump that takes you from the very bottom to the very top... i can't do it from right to left (i can't do that jump diagonaly from the bottom right to the uppper left) It seems the diagonal right to left in the super jump is disabled, but oddly enough, i can do that super jump from left to right.
Can anyone help here?
A few Spectrum game fixes.
Alternatively, you can select the "Keyboard(Turbo)" option, which makes every jump a super jump.
First i had to learn how to insert a POKE code since i never had inserted one in my life.
When i finally learned how to do it instead of "shift" i got the "caps lock" key as my super jump key, it was kind of annoying to have a locker opening and closing in the middle of the screen everytime i super jumped... (the laptop was always warning me of this change - meaning the case sensitive warning).
Having a bit of sensibility to computers and codes (since it's not at all my area) i simply tried a different value i inserted 253 instead of your 254 and i got the "A" as my super jump key...
Great to be able to get all those sparkling bombs again
Thank you
Thank You
And thank you all good peolpe
Or you can buy an inexpensive Logitech K-120 that handles four or five keys without problem, depending on combination up to six keys (plus modifier keys). It's the only keyboard I own that allow press the V-I-C-T-O-R keys in Abu Simbel Profanation!!!. :D
