Lots of French stations booming in on the FM broadcast band.
Don't know if any of you fellow wosser's are interested in receiving/listening to long distance radio but currently here in the Lincolnshire area of UK, I have be receiving lots of French stations literally wiping out the UK stations. This is on the FM broadcast band. One signal is so strong I'm unable to receive our local Lincs FM on 102.2 due to co-channel interference of the a French station. Tropics are very good on the FM band this evening. If your in the UK and have an FM radio with good reception nearby, have a listen.
Best try the web.
You made a good choice getting one Mark. Versatile little scanner with continuous frequency tuning, and the ability to select different modes. I bet these were quite expensive when new. Certainly very chuffed with mine. Shame a lot of radio users have gone digital now. Below 30Mhz is still very interesting though.
When the last Concorde landed at Filton airfield, I used it to listen to the chatter. But did not think to take an audio cable to link it to the camcorder I used to take a video of Concorde on it's final approach and as it flew almost directly over us as it landed.
Next challenge is RTTY, SSTV and NOASAT.
Diddleiddle-iddleiddle-oooooo-boo
boobleoobeeeepply-beeeepply-beeeepply-beeeepply-SCRRKKY-SCRRKKY-BRRRKKY-GRRRRKK-GRRRRKK-GRRRRKK-GRRRRKK...
jonesypeter - Really good value for money those. If you haven't yet try tinkering making up some antenna's, and remember height is might!
