Hi
I'm seeking a Wizard's Lair Sprite/Graphic sheet for a project I'm considering.
Does anyone have one or know the address of one (I know SOMEONE will say "do one yourself!") but no point re-inventing the wheel!
I did a little work last year trying to work out the data format of the rooms. This included a program that dumped the various tiles a room can be composed of in .PPM format. I've put it (and the resulting PPM files) at http://www.seasip.info/ZX/wizlair.zip .
The 16x16 tiles for collectable objects are from 0xF90C to (I think) 0xFFAC.
Click on the picture file, it will open a new browser, then click on "download original image" and it will save it to your 'downloads' directory as a .gif file to bung into your favourite art program.
Probably calling the ROM routines. It's too much hassle looking up all the algorithms and writing your own line-drawing routines unless you really need the speed for vectors and 3D.
(If you really want to, Google 'Bresenham', but for God's sake don't click on the Wikipedia entry as like anything mathematical it's so far up it's own @rse it can see its own tonsils).
The Sprites are the most useful as I can easily grab the graphics from maps here on WOS.
Regards
SKR
Saving me loads of time and head-scratching
Again..... Cheers!
It doesn't seem to be tile based (or is it?)
TIA
SKR
SKR
Did anyone come up with a routine to remove/disable the baddies and/or no-pass items, to allow movement with impunity?
I know it's a long shot, but worth a try :)
TIA
SKR
