Has anyone checked out AMOS2
I just watched this:-
It looks promising but when I went to the guys site http://amos2.net
I didn't think I could manage to install it manually without screwing up, so I'll have to wait and see if an installation shows up. The French guy seems a decent sort, very enthusiastic, looking for people to help out with beta tests etc. It looks like AMOS2 just might be the dogs **** for Basic game making, probably easier than most if the video is to be believed.
Anyone else checked it out?
Thanked by 1Luny
I did have an earlier version of Blitz BASIC on my old PC, though didn't use it much.
It even has programmable sprites (and their software counterpart called "BoBs" )
It's well worth a look especially for fast prototyping.
Amos2 is in it's infancy, but I really suggest you checkout Amos (pro) on AMigaOs/UAE before embarking on this journey.......
I googled AMigaOs/UAE and got several suggestions but not being the worlds hottest PC user I'm afraid to attempt anything that might screw up my computer! The partitioning the disk suggested by one site sounds like trouble!
AMOS is distributed on a disk as a 'zipped' file, so the idea is that you unpack it onto somewhere else before using. This is a bit more hassle in the 90s (nowadays you can just unzip compressed files onto your PC, but back then not everyone has a hard drive), and it's scary if you never done it before. I'd probably watch how other people do it on Youtube instead of doing it yourself.
So why did I ask? Well because I rather liked the idea of making a small test of some pictures I drew for Luny's Dun Darach and it seemed like this might be an easier way to make a short animated demo. Even if it wasnt any use to Luny who is using a different bunch of programs anyway, it might have been fun to give it a try and I have always had a soft spot in my heart for Basic. I've got more damn Basics than I know what to do with, I always fall for the suggestion that THIS is the DEFINITIVE best one of all. I never learn.
First (as with the Spectrum) You'll need an Amiga Emulator...
http://www.winuae.net
This is by far the simplest and IMHO the best for the PC.
HOWEVER!
You will also need an Amiga ROM (called a Kickstart Rom) to be able to use it.
I'm sure you can find one out there if you ask around ;)
Once you get the system up & running it is just like using a real Amiga, however if you are not used to emulation and some of the difficulties which can arise, then it's probably not for you.
Also if you are not used to the Amiga, there again is another level of learning.
The problem I have found with many of the BASIC dialects (especially on the PC) is the documentation (or more specifically the lack thereof)
Any language which leaves you to guess how to use it isn't much use.
<Stops Rambling>
https://www.amigaforever.com/
OK that's fine....
However if you are serious about joining the Amiga community I would strongly suggest that you join
http://eab.abime.net/index.php
This forum and have a read around before committing yourself to anything.
Maybe you can save some time/ money ?
If you join using your current ID there I'll try help as much as I can.
I'm no guru, but been through most of the emulation pitfalls
which are not to be discussed here, as it's a different platform.
(Sorry mods if I'm out of line)
SKR
I think I'm beginning to detect a hint that it might not be as idiot proof an install as I'd hoped! I visited the forums SKR recommended and a couple of others too and it seems that the overall feeling is that Amiga Forever is perhaps a tad over enthusiastic with their claims for a seamless emulation. Pity. I tried to install WinUAE a few years ago and about the best I got after a hell of a lot of faffing about was a basic bootup screen with the familiar look and icons but bugger all functionality, it was enough to put me off emulators for a long time.
I had the Amiga 1000 and I wasnt impressed with the later versions especially after putting down a LOT of bread on a 2000 which went bellyup in less than a year and before that wasnt really any more use than my 1000. Believe it or not all I want to get out of the process is the use of PPAint since DPAint isnt available and a tracker like SoundFX. No interest in games at all except Marble Madness once in a while.
Hope this conversation isnt breaking the rules Rich? It IS Chit Chat after all but I dont want to upset anybody. You guys are my go to gurus for all my computer probs.
http://aminet.net/package/mus/edit/MultiMedia_Sound
This is the original program I had and the song and instruments it came with
That's not a bad idea, even though I already write in Javascript myself.
This will explain it better than I can.
The description reminds me a bit of Orpheus http://www2.iath.virginia.edu/elab/hfl0137.html which was a hypertext application used for making interactive books and running under DOS, it was incredible. You could make a DOS machine almost behave like Windows, it even had hotspots for putting on your graphics and could exit to another program do whatever you wanted and yet always returned to the original jump off point and NEVER crashed!
I used it to make my own DOS front end that masked the command line completely and showed a screen with pictures for the various programs I used which were hot spotted so that I could go from one to another seamlessly. I've still got on my ancient DOS desktop machine I used for antique software like DeLuxe Paint 2.
Okay SKR. I did what you suggested, joined that forum, and used the same handle.
Actually its quite enjoyable discovering stuff but frustrating as hell when you want to just let rip. BTW if anyones interested you can play with a tracker on the Web. No bloody docs though so much the same problem.
https://www.stef.be/bassoontracker/?file=demomods/spacedeb.mod
Back in the day there were document disks for the Amiga by several groups.
The one I remember is LSD Docs disks
Wether or not that particular tracker was covered, I don't know.
However it may be a good place to start
Directory Opus
It's a text based file manager for Amiga which adds heaps of functionality
IMHO Version 4 is the best, as Version 5+ are more graphics oriented and can be rather slow.
Heres the thing, I darent turn off my laptop because I have the flower icon at the bottom and when I select it it shows me a miniature SoundFX icon, a mini DPaint icon and the Amiga forever one thats some kind of a file listing that shows what you last ran. If i closed it down I'm not even sure I could get them back, well I know they are in the downloads directory but of course that doesnt show up.
Depending on what I open I get a fake floppy load noise an icon for Workbench 3.1 and one called RAMDISk and one called DF0 plus whatever program it is I want to run.
This is all very confusing and not very helpful. I almost wish the Amiga Forever install HAD partitioned the hard drive and turned that portion into an Amiga HD so I could just dive in and out at will. I'm such a crap computer user that I never muck about with things like partitioning in case I do some real damage and lose valuable data.
I thought maybe Opus 4 would display whats on the hard drive but it doesnt seem to.
I know this is Opus 5 but Opus 4 does the same.
