Forum.
This forum software is shite. It doesn't show you you you've started a thread when you've hit save and won't let you delete the thread cos you've posted twice.
Click on the time https://www.worldofspectrum.org/forums/discussion/comment/964921/#Comment_964921
Honestly I think it would be much easier if each post in a thread had a number, and you could put that number in your current post if you are refering to your own or someone elses earlier post, and click it and get taken to the post in the thread.
https://www.worldofspectrum.org/forums/discussion/comment/964929/#Comment_964929
That's more to do with the size of the forum.
I do miss the post counter, I know its under our profile, but I remember when it appeared in posts, if only because if was funy/pathetic in a good way when members would be congratulated for reaching 2000, while the signal to noise ratio was very poor. I think Miles and Beans were two prolific posters at that time circa 2004/5.
When I first joined we had one even older than that circa 2002, ooh my.
Yes, the ZX80 does a much better job.
Rather than that I miss the "Location" field, it always was interesting too see what places people come from.
*** Boring: It can be made to work with 7.3 at least, if not higher if you don't mind editing php but lets not go there.
Always a case of swings/roundabouts when moving between any forum software platform, regardless of from/to what, there's always some differences. There's things I prefer with the old one and things I prefer with the new, probably similar to many.
Could waffle on about the pro's / con's of this vs other but its pointless so I'll not. I did not spend about 10 odd years being a dev/quality/beta tester for no reason for a certain forum software company lol, and no twas not anything mentioned in this topic.
To complicate matters a bit more, "first post" can mean 'first you've not read' in some cases too.
