Stargazer Secrets by CRL
Hello again !
I have a copy of Stargazer Secrets by CRL. It is not mentioned anywhere in the archives, and has a different loading screen to the "Stargazer" program by the same company, so there is no mix up there. Another MIA ??
Post edited by Ginger on
Can anyone else confirm?
Steve
ADJB
It may just be an alternate version of Stargazer by CRL...
I?ll check my copy when I get back home Tuesday.
Steve
I'm sure Spectaculator and other emulators can do screen grabs, but a digi cam shot is fine.
Steve
Karl, if it turns out to be needed just drop it into the post as usual ;).
Cheers
Andy
Steve
CRL released "Stargazer Secrets", which is already dumped and resolved fully, however the loading screen is missing.
The .tap file in the Infoseek record, is also called Stargazer Secrets but was released by a company called Somerville in 1983. A new record for this should be ceated and it should be flagged as STP. The .gif loading screen in the CRL record is from the Somerville version of the utility.
Steve
Ehrm, I'm afraid not :)
If you play the TZX file, you'll find it's the same as the TAP file, except it has something in front of it, with a different loading screen.
So the mystery is indeed solved, but it's just that there's a loading screen before the listed one (which is some sort of mid-loading screen).
That said, a scan of the inlay wouldn't go amiss, allowing me to check the full title; e.g. SU called it 'Star Gazer' in their review.
[ This Message was edited by: mheide on 2005-10-05 18:16 ]
I think I got the asumptions right? You have the CRL version.
Cheers
Andy
